DLT wrote:To help clarify this, I believe:
The common terminal of the typical 1-2-N-B switch of wired to the motor starter, motor alternator, and DC panel. Of course, motor starters and alternators are often wired together, such that they use the same wire.
for the purpose of our discussion, use the outboard motor example in the link above that uses a 1-2-n-b switch and a combiner. you've gotta use the combiner for charging ease regardless if you use the 1 switch or 3 switches.
Thus, if you had the motor running, you could power your DC panel, even if the switch is in the None/Off position, or there were no batteries. Subject to charging capacity versus load issues, of course..
you're confused. switch to "1" and your starter battery is used exclusively to start the motor. switch to "2" and the house battery is used exclusively to start the motor while still running the house lights. switch to "both" and both batteries together are used to start the motor. however, "both" also uses the two batteries together to run the house lights which isn't necessarily good because you could drain your starter battery. switch to "none/off" and when you turn the key you will get nothing. however, you will still get house lights from the house battery even when it's in the "none/off" position. "none/off" only controls the amps to the motor.
but, never ever turn the switch to "none/off" while the motor is running. that is a no-no.
The "1" and "2" terminals are typically connected to the different banks.
yes!
So, most people switch to "1", which is typically the starter bank, and start the motor. Then, they may switch to both, to charge both banks off the motor
you are confused...most just leave it in "1". there is no need to switch to "both" because the combiner will take the charge from the motor and first charge the starter battery. then, once completely charged, will charge the house battery until fully charged. that's the beauty of the combiner.
After they shut the motor off, they switch to 2, to run the house off the second bank.
again, you are confused...you do not need to switch to "2" to run the house. the house battery is already connected as a seperate circuit for the house. you would only switch to "2" if your starter battery died and you now want to start the motor. by switching to "2", "2" now starts the motor and is also used exclusively as the house battery while the starter battery ("1") just sits by itself and receives a charge from the motor via the combiner.
There are all kinds of variations on this... For example, some motors may be wired directly to the starter bank. But, I believe this is the basic "traditional" method.
OK...
These charging relays/combiners simplify this somewhat by allowing you to wire the motor straight to the starter bank and only the DC panel to the switch. In this case, most people probably leave the switch in the "2" postion, relying on the relay/combiner to charge the house bank when the motor has charged (or is charging) the starter bank.
incorrect...again the combiner will charge both batteries regardless of what the switch is set to. when at "1", the combiner charges the starter battery first until it is fully charged, then switches to the house battery and charges until it's fully charged. when the switch is set to "2" and the motor is running, the house battery is charged first, then the starter battery
Chip wrote: True, but note that wired in this fashion, no matter where the switch is set, the house battery is permanently connected to the DC panel and cannot be disconnected without pulling one of the terminals off the battery or cutting the wire.
you are absolutely correct. the only way the starter battery gets on the house circuit is in the "both" position. then both are starting the motor and both are being drained by the house lights.
the starter battery can not ever be used to run the house exclusively nor the house exclusively to start (and not be attached to house lights).
but for me, that's OK. i have to protect the starter battery because there's no way in hull i can "pull start" my 90 TLDI.
in conclusion, i either use my starter battery exclusively to start the motor ("1") or when it's dead i've got a switch to use the house battery to start the motor("2").
but because i have a good starting battery, i rarely need to change to anything other than the "1" position. the combiner does all the work in charging both batteries while isolating the banks from each other.
am i being clear?
