(mid 20 mpg to low teens mph Im guessing)
My feeling is this sort of usage calls for a better tow vehicle with particular attention on the engine selected. I think I would go diesel for this.
Just add the new car option to your Mac list, Blue
Could you please provide me with a resource for this bar please?Harvey wrote:You will also need a crossbar that fastens to the single pole Mac trailer so the weight-distributing bars have connection points. I cant find the web site, but it cost me about $100.
Tom, I think what he's mentioned is called a "Pole Tongue Adapter"... for trailers that don't have an A-frame close enough to the car to attach the weight distribution bars.Tom Root wrote:Could you please provide me with a resource for this bar please?Harvey wrote:You will also need a crossbar that fastens to the single pole Mac trailer so the weight-distributing bars have connection points. I cant find the web site, but it cost me about $100.
I have a Dodge Caravan Sport and a Toyota Sienna, so I'm well experienced with both US and "Jap" vans.. gimee the Toyota anytime - faster, stronger, handles better, gets better mileage... and I'm not fixing it all the bloody time... just had to replace the wiper motor in the Caravan the other day 'cause it stripped its main gear (*never* had that happen in any other car - and trust me, I've had LOTS).... it goes through sway-bar link bushings annually... every once in a while the gauges quit and somehow come back on later (complete mystery there, but a common problem with Chrysler vans)... and now I'm having problems with the battery going dead (yet all the electrics check out OK - alternator, battery and possible drains)..... not to mention that I'm always on pins-and-needles wondering when the tranny is going to cough up and die (also a common problem with Chrylser minivans).... grrrrrrrrr.Tom Root wrote:Not knocking vehicle choice, but I personally wouldn't tow more than 8' Utility trailor with anything offered by any Jap Manufacturer.....
The Ford F150 is made in Dearborn, MI. The F150's engine is made in Windsor, Ontario, Canada.LOUIS B HOLUB wrote:I tow my MacX with a Ford F150, stick shift, v-6, with no problem.....
....I know where some assembly plants are, some American vehicles have foreign parts, etc). Thats what I like about a MacGregor...made in the good ole USA....
The 3500 lbs towing capacity indicates Class 2 towing, class 3 is 3500 - 5000 lbs and even with a class 3 hitch the weakest link is still the class 2 tow vehicle. Having to add a weight distributing setup only complicates matters, on my Trailblazer the manual recommends a weight distributing hitch after 4000 lbs, fortunately that is the most I am ever likely to have with the Mac so I don't need it. Most folks, whether they realize it or not, are really pulling close to 4000lbs when you consider all the extra stuff on the boat. A class 3 set-up is really the minimum requirement and also one has to consider what the legal requirements are in case of an accident, will the insurance company cover you if you are not within legal towing restrictions?The Honda Odyssey can tow an X fairly well. Odyssey towing capacity is 3500 lbs. with a class 3 (6000 lb) receiver and weight-distributing hitch. A lightly loaded X and trailer weighs in at about that weight.
