Re: Honda 50 hp carburetor synchronization
Posted: Sat Jun 14, 2025 1:09 pm
AD and BeFree and others,
Thanks for your sympathy. Let’s make this post today start with a riddle:
When are 6 teeth worth $5000 to $10,000?
Drum roll….
When the teeth are set incorrectly for a Honda BF50A engine timing belt. 6 teeth “off.”
Short story: I fixed my Honda outboard today by readjusting the timing belt to spec.
Long story: (read if you don’t have drying paint to watch….)
1. Didn’t run last year but 2 or 3 times.
2. Put up without winterizing
3. Had cheap gas
4. Recently ran boat but it was obvious carbs needed cleaning. I have done it 10 times in 20 years.
5. Cleaned carbs but resused old parts that actually had a varnish on them. Still didn’t run right. I trusted my carb skills (mistake) and started throwing parts on the wall. Even though they checked out ohm-wise, I replaced the pulser, exciter and charge coils because they looked old. I bought new carb jet nozzles and main nozzles.
6. Engine ran worse.
7. Checked carb sync and only got 7” on each intake. Bad. Then I checked compression and got 40/30/10 psi.
8. Gave up.
9. Got four quotes on engines both 25 and 50 hp.
10. Wanted to pull trigger last week on Suzuki DF25.
11. Admiral said whoa! Go back and see exactly what’s wrong
12. I tell her that I wear pants (too…) and the local mechanic says my rings are rusted out by my description. I should have winterized I tell her.
13. Admiral says “no!” to new engine. I haven’t tried hard enough she nags (oops.. suggests)
14. Today I rethought things and especially the fact that I removed the flywheel and maybe moved the belt?
15. Went to boat. Yep. (After fixing timing belt the compression was 130/130/120, with a bit of sprayed WD40)
16. Came home and gave the Admiral the good news that the engine is fine and I gave her the praise she deserved.
Drum roll….
3. Had cheap gas
8. Gave up.
