Re: Best place for thru-hulls
Posted: Mon Mar 28, 2022 6:41 pm
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=28885
One other small comment. Usually it's best not to line up sensors in direction of flow, when mounting them near each other (if I understand your photo). You want to have reasonably undisturbed flow over them, so you don't mount them behind strakes, centerboard trunks, or other flow disrupting features. Your other transducer appears to be low profile, so you may be fine.
So I think that the tubes are there to ensure that water can easily flow into the forward part of the ballast tank. They probably also offer a lot of structural rigidity. There really isn't a whole lot of space in that "double hull" section at all and I can't imagine there being a lot of room for water to flow freely from back to front without it.
Not sure what year of manufacture but it's a 1999 model year. I do have a fiberglass step at the companionway but it's just a little doghouse with a small amount of storage (I sometimes use it for water bottles). The ballast tank vent is at the forward part of the V-Berth just like most others. I can get a picture of it if that is of interest.OverEasy wrote: ↑Mon Mar 28, 2022 10:17 pm What year of manufacture is your Mac26X?
(Not to in anyway question that you have found what you found and that you have worked to a solution to deal with it.)
But early Mac26X production had a different ballast tank vent location vs. latter units. The early units have a fiberglass step at the cabin companionway that also houses the ballast tank vent. Later Mac26X have the ballast tank vent forward under the V Berth.
Makes total sense. So the forward transducer is the paddlewheel for the water speed sensor and absolutely needs undisturbed flow. The second one is the depth sounder and water temp sensor which is quite a bit more flow agnostic. I wanted the depth sounder to be as close to the centerline as possible which was why I felt that locating it behind the paddlewheel wouldn't be much of an issue.Jimmyt wrote: ↑Tue Mar 29, 2022 5:03 amOne other small comment. Usually it's best not to line up sensors in direction of flow, when mounting them near each other (if I understand your photo). You want to have reasonably undisturbed flow over them, so you don't mount them behind strakes, centerboard trunks, or other flow disrupting features. Your other transducer appears to be low profile, so you may be fine.
