Re: annual desulfation of our batteries
Posted: Fri Dec 31, 2021 4:22 am
Opie thanks for the encouragement to investigate my batteries further. Below is taken from the Trojan website. I was kind of amazed that it said 80% is the maximum safe discharge. But at the same time in the line above it says 50% or less discharges are recommended. As stated above we consider 65% battery level as the lowest before recharging.
Shallow discharges will result in a longer battery life.
50% (or less) discharges are recommended.
80% discharge is the maximum safe discharge.
Do not fully discharge flooded batteries (80% or more). This will damage (or kill) the battery.
Many experts recommend operating batteries only between the 50% to 85% of full charge range. A periodic equalization charge is a must when using this practice
Below is the info from Trojan on equalizing batteries. It appears that Equalizing and Desulfation of batteries are the same thing.
Many experts recommend that batteries be equalized periodically, ranging anywhere from once a month to once or twice per year. However, Trojan only recommends equalizing when low or wide ranging specific gravity (>0.030) are detected after fully charging a battery.
In another place they state that batteries in a solar system should be equalized once or twice per month.
I do not own a hydrometer. Most likely will purchase one. But for now as Be Free says "if it aint broke don't fix it" so we will continue to equalize as we have been doing. Most likely we will do it on a yearly basis from now on. Batteries might be like impellors in an outboard water pump, the more you use them the longer they last, if used correctly. We use our batteries daily on our 6 to 9 month trips. Once again you folks as a group have a lot of knowledge. I spend a lot of time researching stuff but I was not up to snuff on this battery stuff. I was doing what someone told me without research fortunately it was the right info instead of internet blather. Also want to mention again that the Equalization/Desulfation is a mode on our Sterling battery charger that we move from boat to trailer.
