Lifting a Mac 26M
Re: Lifting a Mac 26M
You don't have your location posted in your profile, so do be aware that VC-17 is for fresh water AFAIK.
adudinsk
Post by adudinsk »
Yes, fresh water only, on the great lakes..
AD
adudinsk
Post by adudinsk »
Just wondering.. to recoat the bottom of my 26M, how much VC17 would /should I use?
2 cans? 3 cans?
Thanks
AD
Tomfoolery wrote: Mon Feb 10, 2020 9:38 am I'd bet one would do it, but I can't guarantee that. I think it took three to do the Hunter, but that had the big wing keel and barn door rudder.
I think I used Xylene to cut it, but from a quick web perusal it looks like alcohol is the primary ingredient. Sure doesn't, or didn't, smell anything like alcohol though. I think I still have an unopened can around here somewhere in fact.
adudinsk
Post by adudinsk »
I will buy 3 cans then.. better more and not enough.
Thanks a bunch !
Andrew
It'll keep essentially forever, especially if you don't open it and add the copper powder. So no harm in buying 'too much', as you can use it again next year. I believe it'll keep even with the copper powder added as long as you seal it back up tight, but just don't remember any more.
2 cans
Every spring
No sanding, just wash and apply
To get her off the trailer, what highlander said...
adudinsk
Post by adudinsk »
All done.. and yes.. it took 2 cans exactly!
Lifted it up as mentioned,.. did not take much to get a foam roller under her.. an afternoon job.
AD
