Page 2 of 2
Re: Winch replacement
Posted: Thu Jun 21, 2018 7:05 pm
by dlandersson
Those are what I have also.
paul I wrote:Kurz,
I believe these are the winches that are on my 2000
https://www.ebay.com/itm/NEW-LEWMAR-6-O ... Swrsha4y5O
They were original equipment at the time. I have never had a problem with them. But I also seldom use them.
Like others, I am surprised to learn the latest
series were equipped with plastic winches. Did that carry over to the Tattoo line?
Posted: Thu Jun 21, 2018 11:56 pm
by kurz
aha, so they seem to be the same like these ones... they name it here in EU Lewmar ocean series, but I think it's same:
https://www.svb.de/de/lewmar-standard-w ... l#fullSize
Posted: Tue Jun 26, 2018 5:52 pm
by dustoff
I replaced my marelon winches with the Anderson 10's and the holes fit perfectly. I was very pleasantly surprised.
I used the winches a lot with my 150 Genoa when trying to sheet in tight heading up wind. Now that I have a 105 jib, I only really need them when trying to flatten out the sail when trying to beat as high as I can.
My Marelons froze, so I had to replace them. Plus the Anderson winches are really nice to look at. I use the starboard winch every time I go out to hoist the main halyard tight.
Posted: Tue Jun 26, 2018 10:44 pm
by kurz
cool, nice to hear the anderson 10 will fit with the holes.
I allready ordered anderson. I ask in the shop if the lewmar "ocen" for the same price (listed above) is made of plastic. So the looked for one and told me yes, the inside is made of plastic, the part where the scews go through. So my descision was made for the anderson...
Posted: Sun Jul 01, 2018 2:58 pm
by kurz
I finally got the andersen 10
BUT: How can I open it? Do not get the trick...???
Posted: Sun Jul 01, 2018 3:03 pm
by Tomfoolery
kurz wrote:I finally got the andersen 10
Should be a circlip (Sicherungsring?) around the splined (verzahnt?) input socket. Carefully peel that off like an onion, and the drum should lift off. Don't scratch your new winches up doing that, though.
Posted: Sun Jul 01, 2018 3:19 pm
by Jimmyt
If you didn't have a manual, here are the pages...
Posted: Sun Jul 01, 2018 4:44 pm
by Tomfoolery
Ah, there it is - item number 1. Sicherungsring.
Posted: Sun Jul 01, 2018 5:00 pm
by Jimmyt
Gesundheit!
Posted: Sun Jul 01, 2018 5:52 pm
by Tomfoolery
Danke schoen!
Posted: Mon Jul 02, 2018 12:08 am
by kurz
Yea, of course I have the drawings with the numer 1 Sicherungsring to take out.
My personal problem is that I am toooo stupid to get it out. ...
Posted: Mon Jul 02, 2018 4:40 am
by Jimmyt
https://m.youtube.com/watch?v=GjKPt2ca7yI
This guy pulls a snap ring in the video. Maybe this will help. If your snap ring has holes near the gap, you can use snap ring pliers on it - which may make it easier. You'll need the external type which expand the ring when you squeeze the pliers. You can get it, just walk away if you get frustrated, and YouTube your way through it. I can't see the details on your winch to judge what your problem is. If you don't get it in about 10-15 minutes, post a good picture of the top of your winch. Someone will be able to tell you how to get it done.
https://m.youtube.com/watch?v=2JAARdK-GXs
Sample video of various snap ring pliers for general info.
If you use an awl or screwdriver, don't shove it through your hand accidentally. Don't ask...
Posted: Mon Jul 02, 2018 5:59 am
by Tomfoolery
Beat me to it. Here's a page on Spirolox retaining rings, including a video on removing and installing. It looks like those drums use that style ring. I usually have better luck with a very small screwdriver, but whatever works without scratching nice new drums is fine.
https://www.smalley.com/retaining-rings/spirolox
