Posted: Fri May 06, 2005 8:17 pm
You're right about the jib car, Frank... I just brain-farted that one. Corrected now.
Moe
Moe
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
The forestay primarily determines mast rake. The bend is established by the upper shroud pulling the mast aft above the point where it's pushing the swept back spreaders (and hence the mast) forward. However, the forestay being attached at the spreaders also contributes some.delevi wrote:Thanks Moe. I've done most of what you suggested, except tightening the forestay. I did tighten the shrouds to get them fairly snug after they stretched a bit. I'm not sure how much tighter to get them. I assume that tightening the upper shrouds will bend the mast back, causing more sail twist. Won't that counteract the tightening of the forestay, however?
With the friction of a boltrope in a cove, I don't see how, especially without a cunningham, that a halyard alone can get good luff tension. A roller furled jib is sort of in this situation, but has the advantage of not having to be raised and lowered. The luff tape can be nursed along in the foil. And while I won't call it a cunningham, the jib can be tightened in the foil not only by the halyard, but at the tack as well.delevi wrote:I don't yet have sail slugs but plan to get them set up along with halyard leading aft.
See my post above about this... it's how I understand the physics. Most of us with andelevi wrote:As for the traveler, I believe the M is set up the same as the X. I ususally keep it uncleated-letting it move to leeward. Does moving it to winward and easing out the sheet create more sail twist and spill some air?
