Re: EZ-cleats failing
Posted: Thu Aug 10, 2017 10:19 am
In contrast... I don't have the EZ-cleats being spoken of, however, my spring loaded genoa cars occasionally pop out of the tracks, with the detent pin set either forward or aft.
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=26363
Yeah, the track does not go far enough to aft so sometimes I tie off the Genoa sheet at the dock cleat! I know Highlander does not like us to do that but in light wind on a beam reach it sure does help fill up all that canvas. I don't do it in heavy wind.Tomfoolery wrote:That's a valid point. The closer the clew is to the fairlead, the greater the effect fairlead postion will have on the sail, but I've always thought the tracks were rather short for the sail size. I adjust my fairleads to wind conditions, but the jury is still out as to just how much effect that actually has on the sail and/or sail balance.paul I wrote:more confessions.... Not only have I never used either of the winches, I never adjust the position of the genoa blocks. Maybe I should. I guess I just cant see how adjusting them across that 2' span would really do anything.
Holy $hit, I am really taking a lot of lumps on this subject. I almost always tie off the Genoa sheets to the dock cleats. They are so close to the helm. Its so convenient. Can someone explain to me the downside of doing this?BOAT wrote:Yeah, the track does not go far enough to aft so sometimes I tie off the Genoa sheet at the dock cleat! I know Highlander does not like us to do that but in light wind on a beam reach it sure does help fill up all that canvas. I don't do it in heavy wind.
No lumps from me. Using a cleat as a fairlead would allow a lot of twist in the genoa, which is probably good in heavy air with the genoa fully deployed, but passing through a stand-up block, or even the low-profile jib car, then terminating on a cleat should be fine too and still allow some twist to be taken out as usual. I prefer the winches because of their ratcheting action, so I can just pull through the winch and the cam cleat and it all holds while I reposition my hands for another pull, and because they'll hold most of the load when I pop the sheet loose from the cam cleat. No burned hands even with no gloves. But heading up into the wind to luff the genoa would allow pretty easy adjustment of the genoa sheet at the deck cleat, too. I have to try that some time, especially in heavier air prior to furling some in.paul I wrote:Holy $hit, I am really taking a lot of lumps on this subject. I almost always tie off the Genoa sheets to the dock cleats. They are so close to the helm. Its so convenient. Can someone explain to me the downside of doing this?BOAT wrote:Yeah, the track does not go far enough to aft so sometimes I tie off the Genoa sheet at the dock cleat! I know Highlander does not like us to do that but in light wind on a beam reach it sure does help fill up all that canvas. I don't do it in heavy wind.
OK... good. The sheets do always pass through the standup genoa blocks attached to the track (that I never adjust). In fact I tie stopper knots in each sheet to prevent loosing them if they get away from me. The blocks are what stops them, and it makes everything nice and tidy when I furl up the genoa all the way. The sheets wrap around the furled sail and it stops furling when the sheets hit the blocks. Eezy PeezyTomfoolery wrote:No lumps from me. Using a cleat as a fairlead would allow a lot of twist in the genoa, but passing through a stand-up block, or even the low-profile jib car, then terminating on a cleat should be fine. I prefer the winches because of their ratcheting action, so I can just pull through the winch and the cam cleat and it all holds while I reposition my hands for another pull, and because they'll hold most of the load when I pop the sheet loose from the cam cleat. No burned hands even with no gloves. But heading up into the wind to luff the genoa would allow pretty easy adjustment of the genoa sheet at the deck cleat, too. I have to try that some time, especially in heavier air prior to furling some in.paul I wrote:Holy $hit, I am really taking a lot of lumps on this subject. I almost always tie off the Genoa sheets to the dock cleats. They are so close to the helm. Its so convenient. Can someone explain to me the downside of doing this?BOAT wrote:Yeah, the track does not go far enough to aft so sometimes I tie off the Genoa sheet at the dock cleat! I know Highlander does not like us to do that but in light wind on a beam reach it sure does help fill up all that canvas. I don't do it in heavy wind.
Uh, well ... all of them.NiceAft wrote:The question I have is what are the conditions that Dave normally sails in?
Always furling Genoa. Sheets outside armpits.NiceAft wrote:Dave, can you post a photo of what your set up looks like?
I guess I could try that. It would change the angle of force on the EZ-cleat to be parallel with the fairlead, rather than some crazy twist-inducing angle. That could only help.BOAT wrote: I know that I NEVER run the EZ Cleats all alone - I always have the sheet coming from the turn block in front of the EZ Cleat, so that probably would protect the fairlead from getting pulled upward by the sail - I just figured everyone did it that way - I never thought to use the EZ Cleat all alone by itself - I have never used it that way - that might explain why it's never broken.
Okay, that makes more sense to me now - I thought they were breaking.DaveC426913 wrote:I guess I could try that. It would change the angle of force on the EZ-cleat to be parallel with the fairlead, rather than some crazy twist-inducing angle. That could only help.BOAT wrote: I know that I NEVER run the EZ Cleats all alone - I always have the sheet coming from the turn block in front of the EZ Cleat, so that probably would protect the fairlead from getting pulled upward by the sail - I just figured everyone did it that way - I never thought to use the EZ Cleat all alone by itself - I have never used it that way - that might explain why it's never broken.
(To be clear, they're not *breaking*. They fly off, I reel them in, and reattach them.)
