Re: removing wheel
Posted: Wed Oct 04, 2017 1:36 pm
I can't get mine off either, tried putting a tourch on it ? ...the heat makes it expend..
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=26271
I will suggest two things , Freeze Off most auto parts stores have it , it works were you can not apply heat. the other is water , put water in a spray bottle keep spraying and tapping on the wheel, water makes rust, and will weaken the rust tapping will brake the rust loose and more water will wash the loose rust away. Do bang hard just tap. One or the other will get it off.MaritimeMenace wrote:I'm totally having probs removing my wheel.
applied penetrating oil, tapped the center stud a bit with a hammer, but kept rethreading the nut so it wouldn't mushroom.
Used a Harbor Freight gear puller, But now the center stud has fouled thread.
i was able to get the nut back on, but am apprehensive about messing with it anymore because I don't want to ruin anything
