Page 2 of 4
Re: Galley mod from the cup holder thread.
Posted: Tue Jun 13, 2017 3:22 pm
by sailboatmike
I would look at a leather sleeve to protect the hose, leather has been used for 100's of years for protection, I mean I cant remember ever seeing a set of motorcycle rubbers :P (well maybe at one of those late night adult stores :evil: )
Just cut a square and use a couple of cable ties to hold it in place.
Posted: Tue Jun 13, 2017 5:41 pm
sailboatmike wrote:I would look at a leather sleeve to protect the hose, leather has been used for 100's of years for protection, I mean I cant remember ever seeing a set of motorcycle rubbers :P (well maybe at one of those late night adult stores :evil: )
Another excellent idea, I just don't think I will have a problem. I will though, remain alert to the potential chaffing. I have now looked at the gas line with wizened eyes. That line just does not budge. I truly believe the precautions I took were good ones. The ideas presented to me here, were much better ones. 8)
What I now need to do, is find a sniffer/alarm. That was Highlander's suggestion. Yo J, what did you use :?:
Posted: Tue Jun 13, 2017 6:20 pm
Ray,
I would't lose sleep. Looks pretty solid and an easy inspection point.
As I said, statistically boat explosions from propane are fairly rare. I think compressed gas has a bad reputation. Probably mostly from land based explosions.
Gasoline, on the other hand, is responsible for many boat explosions.
Nice work overall. You've done more work than most to protect gas leaks.
Posted: Tue Jun 13, 2017 6:27 pm
Thanks Russ,
Everything I did was based on a conversation with RIS. His suggestions were a big help. I just did the labor, and a lot of thinking before I started cutting. Boy did I cut a lot of holes in my boat.
Posted: Tue Jun 13, 2017 8:39 pm
by Highlander
NiceAft wrote:Thanks Russ,
Oh Yeah Ray !
I think u got a long way to go before U catch up with me :D :D :D
Posted: Wed Jun 14, 2017 2:38 am
Oh Yeah Ray !
Great! You responded to the above, but not to this.
Posted: Wed Jun 14, 2017 9:33 am
by Highlander
Ok Settle down here,s the one I used
http://i844.photobucket.com/albums/ab1/ ... m2xlyq.jpg
http://www.marineoutfitters.ca/index.cf ... 5456601113
There r other ones on the market but they r twice the price!
U happy now :P
Posted: Thu Jun 15, 2017 12:36 am
by sailboatmike
While your there might as well get a CO2 detector for the boat for when you are cooking.
CO2 can build up very quickly if you dont have good ventilation, a few deaths on boats in recent years due to CO2 poisoning
Posted: Thu Jun 15, 2017 12:48 am
by kurz
sailboatmike wrote:While your there might as well get a CO2 detector for the boat for when you are cooking.
Can you prove this?
Posted: Thu Jun 15, 2017 4:17 am
by sailboatmike
Can you prove this?
In the UK alone each year around 40 people die and over 4,000 are injured as a result of carbon monoxide poisoning. The MAIB has investigated three double-fatalities due to carbon monoxide on boats since 2013, in North Yorkshire, the Lake District and Norfolk. An investigation is also underway after a man was killed by carbon monoxide poisoning in Cardiff onboard a privately-owned cabin cruiser just last month.
Read more at http://www.yachtingmonthly.com/news/car ... FKux7X8.99
Posted: Thu Jun 15, 2017 4:26 am
I believe you mean carbon monoxide, not carbon dioxide.
Carbon dioxide (CO2) is what we all breath out.
Carbon monoxide (CO) is produced from burning propane, butane, etc.
Posted: Thu Jun 15, 2017 4:47 am
by paul I
There is a bill being worked on in the New York State Senate right now to require CO monitors in any boat with a closed bow. It would make NY the second state in the US to require such equipment (Minnesota maybe was the first?). I initially questioned the need for a CO monitor on a boat with an outboard, but after being reminded of the possibility of cooking on the boat with a fuel source (which I don't do) I can see how it makes sense. I can envision a preponderance of new marine CO monitors coming on to the market, all at obscenely high marine style prices.
Posted: Thu Jun 15, 2017 5:34 am
Thanks :!:
A CO monitor is now on my list.
Posted: Thu Jun 15, 2017 6:31 am
by kurz
I recently talked to a professionel chemnistry teacher. And he said that it will practically not be possible to bring enogh CO2 or CO in a boat cabin to get a danger from a alcohol stove.
As long as the cabin is not sealed - what the mac not is.
So I can't say more. Don't know who is right now.
If you make help videos I think they should give better information to you.
Posted: Thu Jun 15, 2017 6:48 am
by Seapup
Thanks :!:
They are cheap enough, under $20 at walmart and less online for CO. Same with propane, type 12v propane alarm into ebay and they start at about $10. I can't imagine the stovetop creating a CO issue while cooking though. We did have our CO alarm go off this winter when the exhaust flue on the propane fridge which runs 24/7 became dirty.
P.S. A 1lb gas canister will only be attached when using the range top.
Saw these recently, they are under $20. Brass fitting with vent so you can fill them the whole way and won't rust. The lehr people have had some good reports of them holding up.
