Re: Batteries and electrickery
Posted: Mon Nov 02, 2015 8:45 am
If you are replacing batteries and they fit use a Group 27 battery instead of a the Group 24 battery ....RobertB wrote:....What is working well now is two house batteries side by side under the ladder (as installed by Mac Factory Sales) size 24 I believe.....
GROUP NUMBER: 24
Trojan Battery #:T24-GEL (GEL)
DIMENSIONS IN INCHES*: 11.13" 6.60" 9.25" LxWxH
Amp Hours (AH): 80
27BCI GROUP NUMBER: 27
Trojan Batter #: T27-GEL (GEL)
DIMENSIONS IN INCHES*: 12.00" 6.63" 9.06" LxWxH
Amp Hours (AH): 90
..... Notice the the 27 is slightly longer but is 90 (AH) vs. 80 (AH) so two of them would give you 20 more AH capacity at 180 (AH) vs. 160 (AH). Also remember that even though they are called a deep cycle they are actually a hybrid between a true deep cycle and a start battery. A true deep cycle such as the 6 volt batteries used in golf carts have thicker plates and will last longer and not be damaged (longer life) by repetitive discharges like the marine 24 and 27 batteries.
If you are running two 12 volt batteries in parallel while in use and in charging they are going to have a longer battery life vs. using one and then the other since you won't draw them down as far which will increase their life and also they will recharge faster vs. charging one battery and then the other battery. If you have two 12 volt batteries and only use one but have them connected via a combiner you will keep them both charged but will keep pulling the house one down further as the other one isn't contributing to the house loads. If you have two house batteries and a start battery then for sure use the two house batteries in tandem to make the whole system more efficient. If you only have two batteries and no start battery then I'd just buy a small emergency start battery pack in case you somehow run the house batteries down to the point they wouldn't start the outboard.
Also you can increase the efficiency of the two batteries in parallel if you wire them properly...
The diagram above shows the most common way people wire them in parallel but is not the best way as electricity takes the path of least resistance and that could be through one battery or the other and not necessarily equally through both under discharge or while charging. Especially if they aren't exactly the same brand, group size or age. It is still way better though than using one battery at a time.
... above you will notice that the positive wire attaches to the positive terminal of one battery and the negative wire attaches to the negative battery of the other battery and there are jumper wires between the positive and negative posts of both batteries. This ensures that current path is through both batteries.
You can't use a 1-2-Both-Off switch wired like above but you don't have to. Use the switch if you have also a start battery or just use the switch to turn the batteries off if needed. If you have that rare case happen where you actually have one battery catastrophically fail just remove either the positive or negative jumper going to it and you will be the other battery only.
Now look what you can gain by going the 6 volt route with two 6 volt batteries wired in series to produce 12 volts.
6 Volt Deep Cycle Batteries by BCI Group Number
Trojan Battery #: T-105 (WET)
MK Battery #: 8GGC2 (GEL)
DIMENSIONS IN INCHES*: 10.38" 7.13" 10.88" LxWxH
Amp Hours (AH): 225
The T-105 is shorter than the 24 and 27 and slightly wider and taller but besides getting a battery that will last much longer under repetitive discharges the amp/hr capacity is 225 (AH) vs. the 27's 180 (AH). Since you need two 6 volt batteries for the 12 volts you have a combined AH of still 225. Still that is quite an increase vs. the group 27's and even more compared to the group 24's. I found T-105's new in Florida for about $95 each.
Don't worry about starting the outboard on T-105's as guys use those to start the diesel's in their sailboats all the time,
Sumner
The MacGregor 26-S
The Endeavour 37
Mac-Venture Links
