Page 2 of 2
Re: Favorite Smart Phone Apps?
Posted: Wed Jul 22, 2015 4:14 am
by tewharaunz
The Navionics iPhone app is cheaper and it will run on both so you can try it first. I have a cheap waterproof case that has a loop for a lanyard.
http://www.aliexpress.com/item/Selljims ... 92546.html
Posted: Thu Jul 23, 2015 2:07 am
Neo wrote:Thanks Guys,
I've downloaded most of these on my iPad. With regards to Navionics, it's available in HD for the iPad .... Is HD worth the extra expense?
UPDATE!
Bugger!.... Just remembered that my iPad does not have 3G/4G or GPS support ... so pretty useless!! ... Will have to spend more dollars!!
Also what do you iPad users use as case/enclosure for your iPad?
All the best.
Neo
You can tether it to a phone, or just use the Navionics like a chart.
I use mine under the enclosure in bad weather or up top in good. No case.
Posted: Thu Jul 23, 2015 3:36 am
by RGF
I use the LIFEPROOF NUUD waterproof case for my IPAD AIR 2. There is also a LIFEPROOF FRE' case for older IPADs.
Posted: Fri Jul 24, 2015 5:00 am
by Neo
Catigale wrote:You can tether it to a phone, or just use the Navionics like a chart.
Yes, but I don't know of a way to Tether to a GPS receiver, so to speak
Posted: Fri Jul 24, 2015 5:01 am
by Neo
Thanks again Kadet
Posted: Fri Jul 24, 2015 5:19 am
by danc1957
Neo wrote:Catigale wrote:You can tether it to a phone, or just use the Navionics like a chart.
I believe there are Bluetooth GPS pucks on the market that should be able to interface with an IPad, haven't seen one in awhile though...
Found one here:
http://bad-elf.com/pages/be-gps-2200-detail
