Re: Anchor Light - Crazy idea
Posted: Fri Jun 26, 2015 5:44 pm
If you read some cruising forums, it would seem it's not that uncommon even today. If you can believe what you read on the internet, at least.
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=24354
This works well as it clearly defines the outline of a sailboat and can give boats in transit a good interpretation of what they're looking at and how far away it is. Adding a few points of light (other than downward facing flood light) can really cause confusion. It's not just making sure that you can be seen from a distance but that others can determine what you are, where you are and where they are in relation to you, others and other nav aid's. Adding additional white light can make you look like a larger vessel and give false interpretation of distance, adding a couple yellow lights, now you might be a vessel in tow. When you're underway in the dark your mind plays serious tricks on you, distances get muddled as does your position and you start to question your instruments. Lights cannot always be interpreted from a standstill either and a group of lights muddled together can be any number of things, is that a house? Two boats moving together / past each other? A busy Anchorage? A UFO? "Well none of the light combinations I see make any sense based on the standardized navigational light patterns...must be the shore?" Just things to considerLoala wrote:I was thinking about creating a long string of solar lights to run up the forestay, over the masthead, then down the backstay. (But haven't had time to do it yet.) I've seen this done a couple times during some harbor parades we've had down here in Newport/Balboa. Looks pretty cool!
Been thinking about this and I'm considering getting a battery Anchor light (like Russ's) and fitting a couple sail track sliders to it, then hoisting up the main track ..... Any thoughts on this?BOAT wrote:Back in 1974 I actually hoisted an oil lamp up the mast when anchoring in the Sea of Cortez! That was not an insane thing to do back then, now it would seem crazy.
Back in those days it seemed all boats had a big bird beak chicken head thing on top of the mast and up there were always extra turn blocks for stuff like topping lifts or bosuns chairs and so forth. My dad used to haul me up the bosuns chair in the dark at anchor to wrap bungees around the mast to stop the halyards from slapping in the wind because my mom would wake up and complain that she could not sleep from the halyards slapping the mast. The same line that hauled me up in the bosuns chair was used to hoist the anchor light. That meant that every night I went up there it was in the dark.Neo wrote:Been thinking about this and I'm considering getting a battery Anchor light (like Russ's) and fitting a couple sail track sliders to it, then hoisting up the main track ..... Any thoughts on this?BOAT wrote:Back in 1974 I actually hoisted an oil lamp up the mast when anchoring in the Sea of Cortez! That was not an insane thing to do back then, now it would seem crazy.
All the best.
Neo
Must have been cold holding that oil lamp all night in the darkBOAT wrote:Back in those days it seemed all boats had a big bird beak chicken head thing on top of the mast and up there were always extra turn blocks for stuff like topping lifts or bosuns chairs and so forth. My dad used to haul me up the bosuns chair in the dark at anchor to wrap bungees around the mast to stop the halyards from slapping in the wind because my mom would wake up and complain that she could not sleep from the halyards slapping the mast. The same line that hauled me up in the bosuns chair was used to hoist the anchor light. That meant that every night I went up there it was in the dark.Neo wrote:Been thinking about this and I'm considering getting a battery Anchor light (like Russ's) and fitting a couple sail track sliders to it, then hoisting up the main track ..... Any thoughts on this?BOAT wrote:Back in 1974 I actually hoisted an oil lamp up the mast when anchoring in the Sea of Cortez! That was not an insane thing to do back then, now it would seem crazy.
All the best.
Neo
And I was cold too.
All the best.
Neo
That's a great idea, but 'boat' is a MacGregor M boat and does not have a backstay. Backstays can be handy for lots of stuff, but in the long run I am better without it because I trailer to the marina every time I go out and rigging is easier without a back stay. At first I really missed having a backstay but now I have become accustomed to it.RussMT wrote:Neo wrote:
Having the light close to the mast might create a blind spot for the light. That's why I put mine around the backstay.
BOAT wrote:That's a great idea, but 'boat' is a MacGregor M boat and does not have a backstay. Backstays can be handy for lots of stuff, but in the long run I am better without it because I trailer to the marina every time I go out and rigging is easier without a back stay. At first I really missed having a backstay but now I have become accustomed to it.RussMT wrote:Neo wrote:
Most boats have backstays, 'boat' does not.
Gosh, I don't know. I guess I need to look up the quibble to see what it is . . .dlandersson wrote:Isn't the fact an "M" does not have a backstay a bit of a quibble?
