Re: greasing bearings and alittle trickle of water came out
Posted: Thu Mar 26, 2015 4:41 am
From the AAA site, though a half-dozen other site I checked said essentially the same thing in one form or another.bahama bound wrote:i think the technical law is over 3500 lbs
Georgia
Every combination of vehicles must be equipped with service brakes that are capable and adequate to control the movement of and to stop and hold the vehicle with any load and on any grade on which it is operated.
Every vehicle manufactured or assembled after June 7, 1949 must be equipped with brakes on all wheels except trailers and semitrailers of a gross weight less than 3,001 lbs. as long as the total weight on and including the wheels of the trailers does not exceed 40% of the gross weight of the towing vehicle when connected to the trailer.
Every motor vehicle manufactured after July 1, 1964 and used to tow a trailer or semitrailer must be equipped with a means for providing that the towing vehicle is capable of being stopped by the use of its service brakes.
Every motor vehicle, trailer, or semitrailer must be equipped with brakes that have a braking system arranged so that 1 control device can be used to operate all service brakes.
South Carolina
Every trailer of 3,000 lbs. GVWR or more must be equipped with brakes on all wheels.
