Page 2 of 2
Re: auxiliary motors ??
Posted: Tue Mar 03, 2015 3:47 pm
by mrron_tx
Thanks Marc , I will get the tape measure , pencil and level out soon and see how it all works out for Me :) Hopefully I can measure twice ,drill once :idea: Thanks again. :D Ron.
mdeane wrote:Ron,
Our M is a 2005, not sure if there are differences with 2011 M.
The "snazzy fiberglass piece", as you call it, is 5.5" wide x 9.5" high, roughly matching the purchased motor mounting bracket.
The mounting face is in the same plane as the centerline of the transom. If I were to do this again, I would make the mounting faces parallel but moved out 1.5" to 2" to provide a little more clearance between the motor power head and the transom.
The vertical centerline of the motor mounting bracket is 6.75" from the vertical centerline of the starboard rudder.
Bottom of the "snazzy fiberglass piece" is 1" above the top of the rudder mounting crevice.
Disclaimer- This works with the 3 HP motor & mounting bracket make and model I have, any other combinations may not work as well.
Marc :macm: 8)
Posted: Mon Mar 09, 2015 8:45 pm
by Highlander
mdeane wrote:Ron,
Disclaimer- This works with the 5 HP motor & mounting bracket make and model I have, any other combinations may not work as well.
Marc :macm: 8)
Hi Marc
would u be able to give us the top & bot thickness of ur spacer brkt for the transom , on both sides & explain what the reason is for changing it from an angle to a parallel "vertical" angle, ur input would be greatly appreciated
John 8)
