Page 2 of 2
Re: Making the hank on jib fit a CDI furler-Help
Posted: Tue Nov 25, 2014 11:40 am
by seahouse
And to derail the digressing train completely…
I use a 5 foot length of 1/4" by 3" wide plexiglass between the mainsail and mast at the spreader bracket. It has four 1/2" holes drilled in it to allow heavy duty releasable cable ties to pass through and positively attach it. The foil still curves, but at a much larger radius that easily straightens after it's raised. I would suppose a piece of 3/8" or 1/2" plywood of the same dimensions would be flexible enough to serve the same duty, at reduced longevity.
I use an extended boat hook (something that's already on board) as a support for the overhang at the bow, and a boot (made from buoyancy compensator fabric, but a scrap of canvas would do) that snugly slides over the furler drum and line and overhanging part to hold it all together, and make it weather and (highway) windproof.
Originally I used the jib sheets spirally wrapped to hold the whole thing together, but don't like the time spent to spiral and unspiral it, and it takes time to loosen it for, say, storage; although it does look nice, and they're always there to use in a jiffy.
I also use various sail ties, and the ball-end bungee loops (they have faded a bit, but still holding up), but have discovered that more and more I am using the heavy duty trigger-releasable cable ties to supplant these, both for lashing the mainsail and mast, and for general boat duties. (Also used to secure the mast to the roller at the stern support).
They are instantly adjustable independently in both length and tightness (unlike bungees), fit in your pocket, can be connected to make them as long as needed (without concern about them coming apart), and are positive and solid in their holding power. You can loosen them enough during storage so they don't leave "bruises" in your sail, but still hold positive for trailering.
And practical for many other uses on-board, like securing fenders from bouncing over board. And maybe for handcuffing pirates. :cry:
OK, now back to our regularly-scheduled programming, the original thread topic... Maybe. :?
Posted: Wed Nov 26, 2014 7:52 am
by gabid
GUNNSLINGER wrote:Does anyone have information on how to make the OEM jib (Hank on) fit a CDI furler? :macx: I have a '97 26X
I did mine 2 years ago. I bought the luff tape for my furler from sailrite.com ( I paid around $2.50 / foot). You have to pay attention to what tape # your furler requires. I cut off with scissors about 2" off the sail's luff , then I sewed the new luff tape.
With a decent sewing machine ( I have an old Singer), all together it will take 1.5 hours.
Sailrite site has videos on how to do it, also they have kits.
Posted: Fri Dec 19, 2014 10:31 pm
by Dirko
I had a Doyle jib that had a line sewn into the luff. I was able to pry off the hanks and feed it through my foil. Worked like a charm.
In addition to supporting the furler beyond the end of the mast with a piece of three inch baseboard, I bought a huge roll of saran wrap from the dollar store and wrapped it around the furler and mast when I stored it.
