Re: Considering Re-re-Power: Am I Crazy or What :|
Posted: Wed Nov 05, 2014 11:44 am
Etec 135
POWER & PERFORMANCE
What’s the goal of power and performance? Simple. Beat everything on the water in everything from speed and torque to fuel efficiency. Whether you’re running slow, fast or anywhere in between.
Instant throttle response
When you say jump, we jump. Out of the hole and across the entire performance curve. Not just select points. The key is that every revolution is a power stroke. That means twice the power strokes of a four stroke. Plus, the computer-controlled engine management system delivers the perfect fuel mix directly to the combustion chamber for hair-trigger response.
Less fuel
The engine management system makes more than 8 million calculations per second. You get the precise amount of fuel you need at any given rpm. Not a droplet more. A big advantage when you’re running big water. Plus, you’re buying 87 octane fuel – not premium, like some two- and four-strokes require.
High torque
The natural two-stroke advantage combined with our super-natural fuel-injection and combustion system. That’ll give you up to 23% more torque than a comparable Yamaha four-stroke. Hole shots? More like sling shots.
High horsepower
Our horses never hold back. You get to your running speed faster. You hold it more consistently. Even when you’re pounding big waves on big water.
Less weight, more power
You’re on plane faster, with less bow rise so you can see the open water in front of you. Simply better control and better handling.
DURABILITY & RELIABILITY
More time on the water. It starts with more time on the engineering table. Every part, every system is designed, built and tested to go the distance. We put a lot more in. You get a lot more out.
Easy starts
First time, every time, with one revolution of the flywheel. No choking, no priming, no swearing.
No break-in period
You go flat-out, right out the box, thanks to our boron-nitrate cylinder bores. It’s your time on the water. Don’t waste a second of it breaking in a four stroke.
Fewer parts, more peace of mind
No belts, camshafts or exhaust valves to break down. You can go a lot farther, knowing your engine will get you back.
Parts that last
Low-friction design for greater performance and longer life, under any load. Parts that are built better, tested longer.
Fail-safe protection
In the event of an overheat or other anomaly, the engine automatically reduces power to protect your investment, giving you a big five-hour window to get back without incurring engine damage.
High performance iridium plugs
More efficient spark, smoother running, longer life.
Sealed fuel system
Air can’t get in. Fuel won’t evaporate. No more gummed-up fuel systems. Your engine is well protected during storage.
Bigger alternators
Nearly twice the available amperage of competitive engines. Run more accessories with more confidence.
CLEAN & QUIET
Evinrude® E-TEC® is about creating memories, not pollution. Fact is, we’re unbeatable on clean and quiet performance, even against four-strokes. We’ve passed them all. And they never heard us coming.
Lower emissions
Three stars from the toughest emission standard in the world – the California Air Resources Board. Plus, we’re the only outboard to win the EPA Clean Air Excellence Award. No other brand of outboards produces fewer reportable emissions than the Evinrude E-TEC family of engines.
In-tune with the environment
No oil changes. No worries about disposal or where the oil ends up. Plus every drop of oil in the fuel mix goes into combustion, not the air or water. You’re saving money and the environment.
No smoke
Thanks to the advanced fuel and oil injection systems. You’ll breathe a lot easier when you’re out cruising a shoreline or trolling a weedline.
Less vibration
Stratified combustion for incredibly smooth low-end performance. An engine that’s born to troll.
Less noise
Comparable to the quietest four-strokes, thanks to our acoustically tuned intake and exhaust and 3-dimensional foam lining. Makes for easier conversation and extra stealth when you’re tossing baits.
SPECIFICATIONS
135 H.O. - Model-specific elements
MODEL WEIGHT SHAFT LENGTH
E135HSL 418 lbs /
190 kgs 20" /
508 mm
E135DHL 418 lbs /
190 kgs 20" /
508 mm
E135HCX 433 lbs /
196 kgs 25" /
635 mm
E135DHX 433 lbs /
196 kgs 25" /
635 mm
Common Elements
Limited Warranty 3 Years Non-Declining
Engine type Loop-Charged V6 60° E-TEC
Displacement 158.2 cu in/2592 cc
Recommended fuel 87 Octane
Emissions compliance CARB 3 Star, U.S EPA, European Union
Recommended Oil Evinrude/Johnson XD100™ Oil
Propshaft HP Factory Tuned for High Performance
Full Throttle RPM Range 5300-6000 RPM
Alternator output Variable Voltage Computer Controlled 133 Amp / 1800W output with Regulator
Fuel induction E-TEC Direct Fuel Injection with stratified low RPM combustion mode
Lubrication Pinpoint oiling
Bore x Stroke 3.6 x 2.588 in / 91 x 66 mm
POWER & PERFORMANCE
Less fuel
High torque
High horsepower
Easy starts
No break-in period
Parts that last
Sealed fuel system
Bigger alternators
CLEAN & QUIET
Lower emissions
No smoke
Less vibration
Less noise
SPECIFICATIONS
E135HSL 418 lbs /
190 kgs 20" /
508 mm
E135DHL 418 lbs /
190 kgs 20" /
508 mm
E135HCX 433 lbs /
196 kgs 25" /
635 mm
E135DHX 433 lbs /
196 kgs 25" /
635 mm
Common Elements
