Page 2 of 3
Re: Solar Trickle Charge - Myth or Fact?
Posted: Wed Dec 10, 2014 8:54 am
BOAT wrote:
mastreb wrote:It is true that keeping a solar panel connected will discharge a battery if its dark. However, all it takes is a diode to solve this problem and if your 5W panel was sold as a battery maintainer, it will have the necessary diode in place to prevent this.
Gee, If I send a lot of power to a solar panel will sunlight come out of it? :?
You have to wire 10 of them in a series and plug into a 110 outlet.
Posted: Wed Dec 10, 2014 9:20 am
by BOAT
LED in reverse! 8) 8)
Posted: Wed Dec 10, 2014 2:26 pm
by Boblee
Yeah but only for a fraction of a second and then kaput.
Posted: Wed Dec 10, 2014 3:21 pm
by BOAT
I'll be sure not to try it.
Posted: Wed Dec 10, 2014 6:02 pm
BOAT wrote:I'll be sure not to try it.
I may have been wrong. Maybe you need 11 100 what panels to make light at 110 volts. Give it a whirl and report back.
Posted: Thu Dec 11, 2014 7:14 am
by BOAT
Okay! Does it matter which way I point the panels? (I probably should do it in the dark to make sure I see the light when it comes out).
Posted: Fri Dec 12, 2014 11:58 am
by Three Gypsies
The sun goes to the south during the winter and pretty much over head during the summer .
So a south facing is best .
Posted: Fri Dec 19, 2014 9:26 pm
by Boblee
Unless you live in OZ and then the Sun goes North for the winter and we try to follow it.
Posted: Fri Dec 19, 2014 11:34 pm
by seahouse
BOAT wrote:Okay! Does it matter which way I point the panels? (I probably should do it in the dark to make sure I see the light when it comes out).
It most certainly does so. However, when connected in this manner, you see, they are then known as slenap ralos, their alter ego, and you must be extremely cautious with them.
Wear sun glasses, and you should point the panels away from your face to avoid sunburn. It's not a procedure I would recommend, because you could get caught in a loop of the time space continuum.
It's true, it's not a myth.
I read it on the internet in the post below.
Posted: Fri Dec 19, 2014 11:35 pm
by seahouse
Says so right there in the post above.
:cry:
Posted: Mon Dec 22, 2014 7:15 am
by BOAT
:cry:
AAck! I'm caught in an endless loop! Last time this happened I was told my weather radar could not only see clouds but if connected in reverse clouds MAKE clouds but they said I had to spell radar in reverse to get the secret code for making clouds. I did not work for me, it did not change my radar unit at all but I guess it works for some people. :?
Posted: Mon Dec 22, 2014 4:56 pm
by mastreb
In point of technical fact, no you won't get "sunlight" (that being broad-spectrum light), but it does emit infra-red, which can be seen with a FLIR.
Posted: Mon Dec 22, 2014 6:36 pm
by BOAT
So the radar will make invisible clouds: radar spelled backwards =
Posted: Mon Dec 22, 2014 10:59 pm
by seahouse
Radar?
:idea: No, it never propagates if I set a gap or prevention. :idea:
Loops? at a spool.
:macm: Camp Mac. :macm:
:( In words, drown I. :(
Posted: Tue Dec 23, 2014 6:44 am
by BOAT
Yup, radar spelled backwards = radar - catch you comin' or goin'
So, is it further to New York than it is by plane?
