Johnson Lever at forestay - shroud mods
Sumner
Re: Johnson Lever at forestay - shroud mods
Post by Sumner »
I'm assuming you have a furler? CDI? If so you probably are aware that they would like to see a toggle at the top and the bottom of the forestay. The CDI furler and the Johnson Lever together allow movement in 2 directions so that might count but I still put one...
.... at the very bottom and ....
...also the top.
More here....
http://purplesagetradingpost.com/sumner ... ng-24.html
...and they aren't very expensive,
Sumner
Our MacGregor 26-S
Our Endeavour 37
Mac-Venture Links
vizwhiz
Post by vizwhiz »
I do Sumner...CDI. I was planning to let the furler/lever be the bottom toggle, as you mentioned. I had not reconsidered the top, although it won't be hard to add one. It's just another inch or so to consider.
wcole wrote:When I installed a Johnson Lever on my forestay on an 26X, I purchased a new shorter forestay with fittings on it (from Rigging Only, or something like that, I believe). This was 10 years ago, but I don't remember it being that expensive.
Thanks Bill. I haven't made the final "go" decision on this yet - but that's pretty much what I plan to do also, if I do it.
