Catigale wrote:Matts MB beast visited us for an evening of cheer in NY - typical MB stuff - overengineered up the whazoo. Very nice ride. Diesel is perfect for towing.
When my 2002 finally gives up, Ill eyeball one of those nice Tauregs from VW with that 6 cylinder TDI...
'Tis true, 'tis true--it does all sorts of crazy stuff we don't need. How many owners will ever actually tow with a GL? Maybe 5%.
We were 4-wheeling with it in Moab, and it was awesome. Went places only Jeeps dared to go. Has "Synthetic Articulation" where it uses the air-shocks to push down opposite the the amount of up push it gets from the most compressed wheel. Brakes any wheel that spins, so you can "three wheel" over rocks no problem. I've got a photo of us crawling over a rock with one wheel in the air.
This photo shows both the synthetic articulation and the artificial wheel lock. the front passenger is being pushed down in opposition to the compression on the driver front, and you can see that the driver rear is entirely off the ground.
Same situation from the rear:
Also has "downhill speed regulation"--you set the speed, push the button, and it will individually brake every wheel to keep the speed going down a steep 4WD descent below the speed you specify, from 4mph to 10mph. More features 95% of owners will never use.
Push a button, and you've got 3" more clearance. Automatically lowers at 40mph. Also automatically "squats" above 55mph by 2" to improve aerodynamics (unless you're towing), and then re-raises when you slow down. Often times we'll pull off an off ramp, and then notice that the truck is sneakily "raising" from the squat position at the intersection. It can be disconcerting because it looks like you're rolling towards the car in front of you.
Gratuitous photo of the GL + MacGregor parked legally on the street in downtown Philadelphia on a one-lane one-way road, just to prove it can be done:
As for fuel costs, Diesel usually hovers around the cost of premium (which all MBs require) and her previous truck was the gas version of the same truck, the GL450. Gas got 14 around town vs. the 18 the diesel gets, and 18 on the FWY vs. the 21 that the diesel gets. Never towed with the gas version, but we just got 15MPH average over 7000 miles towing the boat. I estimate about $5000 lifetime fuel savings over gas for the truck.
Not trying to be an advertisement for it, but of the 20-odd vehicles I've owned in my lifetime, this is BY FAR the most useful vehicle I've ever owned. Having just done this tow with it, I doubt I'd ever tow with anything else. It was just completely hassle free.
BUT: Problems we've run into:
1. No spare. The Diesel emissions fluid (BlueTec) system REPLACES THE SPARE TIRE. So they put HUGELY expensive 20" SUV run-flats on it. By expensive, I'm talking $500 per each. Not kidding. Price them. Ridiculous. Also, nobody carries them anywhere, they're made by only two MFRs, and it's a two-week lead time to get them. We literally had the truck at the dealer for a week waiting for them. It's so bad that we kept all the worn tires from our last replacement to use as spares, and used the worn spare as a mast crutch on the boat for this tow so we would have one with us.
2. Jeeps are cheap to fix. MBs aren't. Because it has serious off-roading capability, you think you can off-road with it. You really shouldn't. Case in point: Running down a wash in Joshua Tree 4WD doing 65MPH. Yes, that's right, 65MPH in sand. Having a blast, truck tracked like it was on rails. Hit the passenger side mirror on a tree, took it off. Price to replace on a Jeep: $110. Price to replace on the GL: $900. Turns out that the integrated blinker, electric positioning, and LCD auto-dimming, and anti-fog heater all came off with the mirror too.
3. MB's DEF (diesel emissions fluid) dealer service is a total scam. Their price to re-fill DEF: $600, including system flush. Price of a gallon of DEF at gas station in Southern UT: $10. Nuff said. Oh, and when it says you're running low on "ad-blue" (DEF), the truck will disable starting when you completely run out. Apparently this is to avoid damaged to the catalytic converters. And by the way, DEF smells exactly like the Philadelphia subway downtown transit station.
So it's good and bad. If I were just buying a tow-beast, I'd get an F-150. But as an all-purpose vehicle, this is the most all purpose I've ever seen any vehicle actually be.
