Page 2 of 4
Re: Bias or Radial?
Posted: Thu May 09, 2013 6:57 am
Same here. New bias-ply tires, mounted on galvanized wheels, to replace the 12 year old originals and 9 year old second (added) axle pair. I've kept the newer ones for spares, and will replace them too when funds allow.
It's hard to beat the mounted tire price from etrailer, and free shipping was just the icing. They showed up via UPS in a couple of days, already inflated. Install, adjust pressure, use the trailer.
Re: Bias or Radial?
Posted: Thu May 09, 2013 7:56 am
u12fly wrote: Besides for me the bias looked better... I ordered my tires from e-trailer. I needed rims (and tires) for my extra axel, and after researching it I just could not beet the mounted tires on rim with free shipping.
Chris.
That's what I got. 4 premounted from etrailer. Cheap and at my door in a couple of days. Went with bias because the radials were out of stock. Probably better off with these.
Re: Bias or Radial?
Posted: Thu May 09, 2013 8:07 am
by Lvoight
I just ordered 2 of these.
http://recstuff.com/st22575d-15c-6-sspoke-1.aspx
seems like an unbeatable deal.
Re: Bias or Radial?
Posted: Thu May 09, 2013 8:35 am
Seems like a good deal to me, too. That's the tire brand I bought. Seems to be fine so far.
15 inch 6-lug? On a 26X trailer?
Re: Bias or Radial?
Posted: Thu May 09, 2013 8:58 am
by Lvoight
tkanzler wrote:Seems like a good deal to me, too. That's the tire brand I bought. Seems to be fine so far.
Yup i got 6 lug hubs. No idea why. I guess i never looked into it before. Those are the tires that are on there now. What do you have?
Re: Bias or Radial?
Posted: Thu May 09, 2013 9:22 am
14" wheels on a 'standard' 3500 lb axle. 5 on 4-1/2" pattern. ST205/75D14 bias ply on galvanized wheels, both axles. The original steel
trailer had one axle, which is still there but was moved forward when the PO's added a second 3500 lb axle. The original axle and leaf springs were actually fairly heavy, but the spindles and bearings are light.
http://www.etrailer.com/Tires-and-Wheel ... 3S450.html
You must have an upgraded axle, which is a Really Good Thing in my opinion, as the original was just too light for any
configured to actually be used.
Re: Bias or Radial?
Posted: Thu May 09, 2013 10:31 am
by Lvoight
tkanzler wrote:14" wheels on a 'standard' 3500 lb axle. 5 on 4-1/2" pattern. ST205/75D14 bias ply on galvanized wheels, both axles. The original steel
interesting. Ill have to check it out more this weekend. I thought the tires in my link were kinda weak at 2100 working lb. 1750 seems awfully light.
Re: Bias or Radial?
Posted: Thu May 09, 2013 10:48 am
Lvoight wrote:tkanzler wrote:I thought the tires in my link were kinda weak at 2100 working lb. 1750 seems awfully light.
I agree, and I'm glad the PO's added the second axle. They had loaded my boat up (when it was theirs
) for cruising, with all sorts of stuff (like a 120V refrigerator) that I promptly ripped out, but I'm sure it was well over the rated 3500 lb gross vehicle weight of the standard trailer, which includes the weight of the trailer itself. I'm sure it still is at least a little over, but I haven't dragged it to a public scale. Probably will on the next road trip, just so I know.
In your case, 4200 lb of tire capacity, plus tongue weight (another 400 lb, more or less) is 4600 lb gross trailer load. That's pretty heavy considering the boat has an empty weight of 2350 lb (plus engine, sails, battery, and on, and on, and on), depending on the trailer's tare weight. My trailer is supposedly 710 lb, but that was with just the original axle. A couple or few hundred more pounds for the extra axle, springs, and wheels.
Re: Bias or Radial?
Posted: Thu May 09, 2013 11:05 am
6 lugs huh? My Mac aluminum trailer has 5 lugs
I looked at them and after shipping the price was exactly the same as these guys.
https://www.etrailer.com/Tires-and-Whee ... 3S862.html
So I bought 4. They came in a couple of days. Now I have to go bolt all this stuff together.
Re: Bias or Radial?
Posted: Thu May 09, 2013 1:08 pm
by Lvoight
What lb of torque is the number you use? I always heard 90 but never have seen it in writing.
Re: Bias or Radial?
Posted: Thu May 09, 2013 1:12 pm
by kmclemore
The trailer manufacturer says 90. I won't even get into the 'dry or oiled' debate... it will suffice to say I do them dry and have never broken a lug or had one come loose.
Re: Bias or Radial?
Posted: Thu May 09, 2013 1:20 pm
by Lvoight
kmclemore wrote:The trailer manufacturer says 90. I won't even get into the 'dry or oiled' debate... it will suffice to say I do them dry and have never broken a lug or had one come loose.
I have never had a new trailer. Most likely why I have never seen the book... haha
Re: Bias or Radial?
Posted: Mon May 13, 2013 5:29 am
by Tsatzsue
I went with bias ply. The reason, as it was told to me, is that when the tire is hot after towing and dunked in the water the steal and rubber from the tire have an issue. Different expansion rates. This leads to separation of the ply and tire failure. Makes sense to me.
Re: Bias or Radial?
Posted: Wed May 15, 2013 6:45 am
by raycarlson
So why wouldn't the steel in the bead of your bias ply tire also fail. This is a totally untrue situation.there is no issue with heat expansion differences between rubber and steel plies or beads.
Re: Bias or Radial?
Posted: Wed May 15, 2013 11:27 am
its on the internet, so it must be ...
(agree with Ray, sounds like urban legend...)
