Page 2 of 4
Re: Quick heron H-412_D Windlass
Posted: Mon Apr 01, 2013 3:42 pm
by Highlander
cut this hinge into 2 sections make two hinges
http://i844.photobucket.com/albums/ab1/ ... 28e7da.jpg
http://i844.photobucket.com/albums/ab1/ ... b66389.jpg
http://i844.photobucket.com/albums/ab1/ ... ed52fc.jpg
http://i844.photobucket.com/albums/ab1/ ... 331e9e.jpg
http://i844.photobucket.com/albums/ab1/ ... d246d1.jpg
http://i844.photobucket.com/albums/ab1/ ... aee94d.jpg
http://i844.photobucket.com/albums/ab1/ ... fb5448.jpg
Here on the port side the aft ss bolt was removed from the bowsprit / anchor roller mounting brkt to temp install a black reg 3/8" X 3" bolt for installing the stiffner brkt's from there to the ancor locker
http://i844.photobucket.com/albums/ab1/ ... 64cc9d.jpg
here is the inside veiw from underneath of the floatation chamber that surounds the ancor locker u can see the stiffner brkt installed between the hull & the ancor locker this will all be attachhed to the rear mounting brkt . the right bolt is coming through from the ancor roller mounting brkt & hull then accross to the ancor locker sidewall this means everything is attached to the deck & hull below the deck hull joint thus releaving any stress from the deck hull joint
http://i844.photobucket.com/albums/ab1/ ... 2c20c6.jpg
inside ancor locker side mounting brkt to be cut once postition of cross brace angle is determined
http://i844.photobucket.com/albums/ab1/ ... 9875a2.jpg
The cross brace will be 3" allum channel , here shown is 3" alum flat bar as a demo
http://i844.photobucket.com/albums/ab1/ ... 4d5644.jpg
anyone wanting to copy these pics for further refernce are welcome
Posted: Mon Apr 01, 2013 4:14 pm
by Highlander
this is all just temp. installed once fitted properly then have to make sure these brkt's will fit the starboard side before marking & drilling the S/B side brkt's & once the inside ancor locker angle mounting brkt's angles have been determined & measured everything will have to be removed to cut these brkt's :( then checked for exact fit then all re-installed this part of the process is very time consuming climbing in & out of the boat a hundred times :x , then onto the front brkt for completion & installation a little more accessible up front above the bow eye access panell the ancor locker brkts r accessed through one 5" round access panell on each side a big pita I may see if I can buy a wall access panell from home hardware the kind u buy for ur house walls for about 20$ be much easier for further access & re-installing the floation :evil:
Posted: Mon Apr 01, 2013 8:15 pm
by seahouse
Truck hinges. Brilliant! So they did almost fall off the back of a truck, then. :D
So how did you come across them in that stage of (dis)assembly? Is there a plant near you?
Nice work as usual.
-B. :wink:
Posted: Mon Apr 08, 2013 4:03 pm
by Highlander
Progress was slow this wk-end , bought more Alum material 65$ , SS hardware $130.00 fri morn , then spent the rest of Fri & Sat with my Daughter & granddaughter :)
So back @ it on Sun morn started with a peice of Alum Angle 6" X 6" 3/8" thick for the front mounting brkt
http://s844.photobucket.com/user/TheHig ... sort=6&o=0
http://i844.photobucket.com/albums/ab1/ ... f22ae3.jpg
http://i844.photobucket.com/albums/ab1/ ... 063342.jpg
http://i844.photobucket.com/albums/ab1/ ... 9e7293.jpg
http://i844.photobucket.com/albums/ab1/ ... fb9ee2.jpg
Now back to the rear mounting brkt's access is through two previous installed 6" deck plates
http://i844.photobucket.com/albums/ab1/ ... 425e5d.jpg
These have now been removed & replaced with a 17" X 17" house wall access panel 21$ giving me lots of room for access for this & many more if needed future mods this also makes it a lot easier to remove & re-install the floation
http://i844.photobucket.com/albums/ab1/ ... b0c5a1.jpg
Here's the panel frame
http://i844.photobucket.com/albums/ab1/ ... 7b9863.jpg
Will post more pic's tonight of the frame installed
Posted: Mon Apr 08, 2013 9:23 pm
by Highlander
Posted: Mon Apr 15, 2013 3:45 pm
by Highlander
more progress
http://i844.photobucket.com/albums/ab1/ ... 1c7a34.jpg
http://i844.photobucket.com/albums/ab1/ ... cf8c69.jpg
http://i844.photobucket.com/albums/ab1/ ... bd113e.jpg
http://i844.photobucket.com/albums/ab1/ ... 5beb27.jpg
http://i844.photobucket.com/albums/ab1/ ... e86193.jpg
http://i844.photobucket.com/albums/ab1/ ... c6e8f5.jpg
Here u can see the peice that came out of th slot cut out as u can see the anchor locker lid has a balsa wood core so after I cut the slot out a little more wider then it will have to be resin core the edges to seal them from the water
http://i844.photobucket.com/albums/ab1/ ... 6c253f.jpg
under the locker lid the center brkt here is just a proto brkt will be replaced with a one peice brkt once I buy more 3" alum angle will post that next wk-end
http://s844.photobucket.com/user/TheHig ... c.mp4.html
Posted: Mon Apr 15, 2013 8:03 pm
by seahouse
When you're done it'll be solid enough that you'll be able to put it to good use in the off-season, John.
As a stump-puller! :D
-B. :wink:
Posted: Mon Apr 15, 2013 8:12 pm
by Highlander
seahouse wrote:When you're done it'll be solid enough that you'll be able to put it to good use in the off-season, John.
-B. :wink:
Brian
I'm completly Stumped !! :D :D :D :P
Posted: Tue Apr 16, 2013 6:09 am
by Crikey
I like the new chain locker.... "To boldly go where no man has gone before!"
Something of the engineer in you, Scotty. :D
Posted: Tue Apr 16, 2013 10:38 am
by seahouse
Ha ha. We're such a bunch of "cut-ups"!
:D - B.
Posted: Sat Apr 20, 2013 12:52 pm
by Highlander
Well bought more material 16" X 3" x3" x 1/4" thick Alum Angle yesterday Fri , & today sat got right back into it freezing my butt off inside both my shops as I'm toooooooooo, cheap !! to heat the joints !! :D :D :D ,
anyway made & finshed off the inside brkt's for the anchor lock
http://i844.photobucket.com/albums/ab1/ ... ab1187.jpg
The brkt looks un-even & lop-sided just due to the angle the pic was taken
http://i844.photobucket.com/albums/ab1/ ... e8d619.jpg
S/B inside locker side brkt
http://i844.photobucket.com/albums/ab1/ ... 0e3e44.jpg
port side inside locker brkt
http://i844.photobucket.com/albums/ab1/ ... a93c4d.jpg
httNew one peice inside locker center brkt
http://i844.photobucket.com/albums/ab1/ ... 036e50.jpg
http://i844.photobucket.com/albums/ab1/ ... b61ff6.jpg
This is the complete brkt's assembly it is a 9 peice alum brkt's & 4 plastic "cutting board" backing plates that once assembled altogether inside the boat it all bolts together bringing the hull on both sides & the anchor locker walls making them a one peice assembley so their is no stress on the deck or deck joint
http://i844.photobucket.com/albums/ab1/ ... 9a88cc.jpg
PS Well going back out now to install my new on firesale glove box :P
Posted: Sat Apr 20, 2013 1:28 pm
by beene
Nice work J
Cant wait to see it in operation this summer
When r we getting together with Rock for beers?
Posted: Sat Apr 20, 2013 3:53 pm
by Highlander
Well got to weld the two end cut-out slots on the center brkt , then paint the inside anchor locker brkt's then the rear brkt's r ready to install along with the front hinged mounting brkts , so tomorrow Sun I have to make the top swivel mounting plates & premount everything to make sure it all lines up perfect , then maybe hopefully next wk-end or the one after if it ever warms up :evil: this monkey needs one more monkey one outside the boat & one inside to install this contraption Oh & a third monkey to be the gofer for the other two monkeys bringing the hardware & Beers & be the center comunication guy passing the Buck back & forth , I said right u dumb A$$ no u'r other right ,S/B > u hear S/B no thats port ur looking @ the Aft of the boat instead of the Bow :? Gez good help is really hard to find , just how many beer's u had already !!!!! :| :P
Posted: Sat Apr 20, 2013 7:52 pm
by Crikey
:D :D :D
Lookin good John! Bulletproof.
Posted: Mon Apr 22, 2013 11:38 pm
by Highlander
Well into the top swivel & base brkt's these r taking alot of time
here's the top mounting brkt with the front hinges mounted with temp pre install fit
http://i844.photobucket.com/albums/ab1/ ... 2fc36b.jpg
Here's the top swivel plate it had to have timed slots made into it so as it can turn from center to either port or starboard anchor rollers
http://i844.photobucket.com/albums/ab1/ ... 683195.jpg
http://i844.photobucket.com/albums/ab1/ ... f37963.jpg
http://i844.photobucket.com/albums/ab1/ ... edf281.jpg
http://i844.photobucket.com/albums/ab1/ ... dde694.jpg
http://i844.photobucket.com/albums/ab1/ ... 9af35d.jpg
http://s844.photobucket.com/user/TheHig ... 6.mp4.html
Sorry moved these so I had to repost them sorry for any inconveince
