Re: Trailer tires for 26X?
Posted: Sat Feb 23, 2013 5:05 am
For 3-4miles 2x per year I think I would drive on flat tires rather than replace
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=21540
Catigale wrote:For 3-4miles 2x per year I think I would drive on flat tires rather than replace
I bought some 15" chrome wheels off Craigslist. With 15" tires I was able to get a higher load rating. My tire guy got me tires that had the same overall dimensions as the originals. Price was something like $10 more than the original 14" tires. Sorry, I'm not sure what size they are.kevinnem wrote: I am not sure I can fit 15 inch ones on the trailer.
A few years back I changed the rims and tires over to 15" on the stockkevinnem wrote: I am not sure I can fit 15 inch ones on the trailer.
silverfox441 wrote:Bias tires are used on trailers for stability and for heavy weight due to a stiffer side wall construction. They do wear faster. I always use bias on my trailers.
When I replaced mine there was plenty of tread left, but the sidewalls had visible cracks due to UV exposure. They would not pass a vehicle inspection in that condition. Each year now I apply Armorall protectant. I'm not sure if it does any good though.dlandersson wrote:Just an observation. My understanding is that you don't want to run your trailer tires until the tread is gone. You should plan on replacing them every 3-4 years. The tire rubber degrades - just like auto tires.![]()
Oh, of course. Should actually have some threads left before it warrants replacement, 6/32 in i believe, for Canada. And like someone else already mentioned, age will be an issue as well, 5 to 7 years depending of the brand, again, for Canada anyway. But this where i think we should be more cautious. When a trailer sits in the same place for a long period of time, the sun will attack the rubber at he same spot over and over again. This could create a weak spot on a tire before it would be deemed to old for use. Hence it's a good idea to use tire covers, IMO. What i usually do is look a the tires of my trailer where they touch the ground where the bulge is at. Look for cracking in the side wall. Roll forward a bit, repeat on and on til i'm satisfied everything is ok.dlandersson wrote:Just an observation. My understanding is that you don't want to run your trailer tires until the tread is gone. You should plan on replacing them every 3-4 years. The tire rubber degrades - just like auto tires.![]()
Azzarac wrote:I replaced all 4 tires last year with Kumhos. With a max load range of 2271 lbs, they had the highest rating of any 14 inch tire I could find. So far I have been very happy with them. Should they begin to fail, I will be replacing them with 15" tires and wheels.
