Re: Buy gas in the winter and use it in the summer?
Posted: Wed Oct 24, 2012 11:51 am
Considering gas cans cost $15 to $40 for a 5 gallon can, can you buy gas for $3 less per gallon to justify the cost of the storage cans?
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=21120
Don't know what they cost, I was given one. Haven't used it yet as all my summer reserve fuel tanks have Stabil in them.Fuel additives and stabilizers may allow water to pass thru filter. Add additives directly to tank.
RussMT wrote:I used to drain the remaining fuel from my 12 gal tanks into the truck at the end of the season. It was a PITA to do and seemed dangerous to move the fuel from container to container. So now I simply add some SeaFoam (1 oz to a gal) to the tanks and run it through the lines a bit before putting her away . Haven't had any trouble. Starts right up in the spring.
Hey Russ – I’ve done this in the past too, and it’s another good strategy. (It’s no secret – I like to experiment). It was made much neater and easier by an accessory fuel nozzle that fit directly in place of the tank cap. It had a large flexible spiral metal spout with a loose-fitting rubber hose that terminated an inch or two from the end of the metal spout. The rubber hose allowed air in at the same time as the fuel was flowing out, so it was fast, and there was no glubbing or spillage. A very neat gizmo, but it is dedicated to the proprietary fitting on the tank, so I sold it with the boat.I used to drain the remaining fuel from my 12 gal tanks into the truck at the end of the season.
