First, I have to say, I had this same outing, about 15 years ago (well similar anyway)
And so did a lot of these other fellows on this forum, at one time or another. So be of good cheer
The 26X is very light and can be very squirrely, when entering and leaving your slip. If you have enough water under you, be sure to keep rudders and centerboard down in this situation. This makes the X much easier to handle at low speeds.
Buy yourself a telescoping boat hook, if there is not one on the boat now. Have someone stand by on the bow with it to catch your cleat when docking (for now..... you'll get much better at this as you do it more)
When docking (and I say this often) SLOW IS PRO
Here's a trick for you. Before you go out, take the dock line you will untie last (when leaving the dock), untie it from the dock cleat and just loop it around that cleat once. Now take the dock line back to the cleat on the boat, that it is looped around and tied the end of the rope there.
If this is a rear cleat on the boat (try for that in fact), you can now untie the bow cleat, climb aboard, start her up and just sit there and untie the dock line from the cleat on the boat and pull the loose end back onboard, drop her in gear and putt out of your slip.
Have the boat hook handy for awhile during these maneuvers, until you get real good at it
This may sound strange, but it is actually a very similar thing.
Do you remember the first time you tried to use a computer mouse? Remember how difficult it was to get that little arrow to go where you wanted it to go? Now you don't even think about it.
Well, boat handling it very similar and will become second nature with a little getting used to it. And, each boat is different. When I sold my X boat and got the 26D. There was a learning curve with it, where docking is concerned, even though I had a lot of experience with several other makes by then.
See, we are used to cars and expect precise steering........... and cars have brakes. Boat have a mind if their own sometimes. It more like getting your dog to heel on a leash, than driving a car. But we are the men... we can train the dog/boat, right?
That's bogus about the Bimini.... My X boat was the same way when I got it. These tall guys huh
When you get to the point of attempting some mods, I'm sure I, or others on this site can give you some help in solving that issue.
Hope I've been helpful..... Go out there and try again. After awhile it'll be second nature.
Oh and try to remain calm. It helps a lot.... I know, 'cause I tend to be a nervous Ned when doing new things myself
Best Breezes,
Steve K.
Mac 26D "Three Sheets"
