Re: Lifeline PELICAN HOOK pin gone wild
Posted: Fri Aug 03, 2012 4:09 pm
Ordered mine on back order 2 wks but less than half the price here !
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=20624
The easiest way (no special tools required and 5 minute installation) is to order a set from Bluewater Yachts. Simply remove the old lifelines (cut one end, unpin the other) then pin one end of the new assembly to the stantion. The other end clips and you simply adjust to the desired tension using a small wrench.2ndWind wrote:Can someone recommend a mod to add a pelican hook to the 2002x lifeline. Thanks in advance.
What fun is thatIvan Awfulitch wrote:The easiest way (no special tools required and 5 minute installation)
Ivan Awfulitch wrote:The easiest way (no special tools required and 5 minute installation) is to order a set from Bluewater Yachts. Simply remove the old lifelines (cut one end, unpin the other) then pin one end of the new assembly to the stantion. The other end clips and you simply adjust to the desired tension using a small wrench.2ndWind wrote:Can someone recommend a mod to add a pelican hook to the 2002x lifeline. Thanks in advance.
http://bwyachts.com/web%20catalog%20312 ... _gates.htm
