Page 2 of 2
Re: Mast Gate
Posted: Tue May 22, 2012 7:55 pm
by Mac26Mpaul
Think he means the bit that the clew bolt goes through, not the reefing hook(?)
Re: Mast Gate
Posted: Tue May 22, 2012 9:02 pm
Mac26Mpaul wrote:Think he means the bit that the clew bolt goes through, not the reefing hook(?)
Right. Not the hook.
The U Bolt thingy. I have the reefing hook, but not that U Bolt thing.
Re: Mast Gate
Posted: Tue May 22, 2012 9:59 pm
by Nick
I had the same arrangement on my old trailer sailer which used a bolt rope. If you have sail slugs now I would suggest carefully hammering the edges of the opening back to their original position and then cutting a small section out to insert the slugs fairly close to the boom so that you may not even need a gate and use the much simpler slug stop instead.
Cheers Nick
Re: Mast Gate
Posted: Tue May 22, 2012 10:23 pm
by NiceAft
Nick,
Is this something you have done, or is it theory
Re: Mast Gate
Posted: Wed May 23, 2012 12:33 am
by Nick
I have only done a partial closure of the gate on my old TS and did not have any problems. However it had a more square profile on the trailing edge so it was simple to tap down the edges. As long as cracks don't occur it should be achievable. Aluminium (aluminum) is fairly malleable.
Cheers Nick
Re: Mast Gate
Posted: Wed May 23, 2012 6:45 am
by Mac26Mpaul
Yep, I did consider attempting to bash it in with a rubber mallet as that will make it much easier - just cut a small piece out as you say, but to be honest, I'm a little scared that my once pretty mast will end up with the two left handed guy - bashed and mangled, kind of a look
Re: Mast Gate
Posted: Wed May 23, 2012 8:17 am
by hoaglandr
I took a hammer to mine and carefully closed the gate to about half its original size. Pretty easy and simple. I was worried about beating on my mast but then I thought of all the holes I had already drilled in the boat and said what the heck.
Russell
Re: Mast Gate
Posted: Wed May 23, 2012 9:20 am
by Sea Wind
I used a piece od wood and a regular hammer, that makes sure that you don't hammer more than nedded and leaves no marks. Also, use your body against the mast.
Re: Mast Gate
Posted: Wed May 23, 2012 3:00 pm
by Mac26Mpaul
alright, I will have to work myself up to it, but I'm gunna give it a go I reckon...
