Re: Changing a Transom (Ballest Vent) Valve from 1.5" to a 3"
Posted: Fri Apr 27, 2012 7:15 am
Only the lower right (viewed from behind) mounting hole is re-usable. (I was hoping this one could be reused.)
Two of the new holes could be through drilled with SS nylocks on the backside. (Do you recall which ones were re-usable. Guessing 1 is the Lower right.)
The other two were tapped course thread for the new bolts. Used a sabre saw to open up the drain hole - do be careful about cutting/drilling too deep into the ballast tank. (I was thinking this could/should be done with a 3" circular hole saw. What are your thoughts? Just nervous about cutting fiberglass for the first time in my life.)
It's obvious when you get the old one off. Had to cant mine slightly to starboard to follow the hull which really work well as the handle shaft lined up with the old extension guide. (Makes sense and this is what I will do with mine. Great idea.)
My handle extension was about 1.5 inches to long so cut with a hacksaw and chucked in lathe to cut new threads. (great recommendation as well.)
Now if I could just get on the water to check out my new ETEC 90. (Did the mod to a 90. NICE. I live in the FL Keys so getting on the water is not the issue.... The 9-5 job is.)
I wish I knew if this was / is going to have the effect I am hoping for. My 2006 50HP Suzuki has never had my 1996 X on plane.
P.S. Come visit anytime.
