innervations wrote:Hi Kadet, apologies for all the questions but really interested in your setup.
1) Raymarine lists the stroke range of the actuator as 10inches. Did that allow you to still get full rudder movement when turning the wheel manually or do you always disconnect the actuator when you need full turning range?
2) everywhere I look describes this as a "removable" tiller pilot so I take this to mean you are supposed to disconnect when not running on autopilot. I guess I am concerned that driving the linear actuator back and forth when steering manually combined with forces coming back from the rudders will damage the unit pretty quickly. What has been your experience?
Thanks heaps for sharing this mod.
1) I centred the actuator before fitting following the Ramarine instructions and have full lock to lock steering, and once setup you can define the travel so it can act as a rudder stop so you don't oversteer under AP.
2) Yes it is designed as a cockpit fitted removable pilot and for long periods of hand steering I would remove it. But this is not how I use my boat so for the short periods I hand steer it is no big issue, the manual even describes steering around obstacles with no mention of removing the ram, and having tried to fit it once underway I can see why, lining up that little pin requires you to move the rudder bar to the actuator as it almost impossible to pull the ram by hand. In a crowded seaway having steered around an obstacle trying to refit the ram would cause you to have to steer a pretty wild course to refit it
With no power to the actuator in standby it is like hand turning an electric motor, yes you will add a little extra wear and tear to the gearing but the thing under power produces 85KG of force and you use it for hours on end, it is designed for a 6000kg boat so out little
s hardly tax the thing. The bit of hand steering I do would be negligible to the total wear on the unit.
I have been out in 12-15 knt winds over canvassed with full main and 150 genny heeled about 30 degrees on a close reach, I normally struggle to hold the wheel against the weather helm in this situation, the AP did not appear to mind
