I, on the other hand, would NOT go 50 miles offshoreCatigale wrote:50 miles offshore i would have spare rudders on board, and also master sailing on course without rudders ...not as difficult as it sounds......
Rick
I've only done it by accident. Asked the admiral to lower the rudders once, and then found out an hour later that only one was down. Didn't notice a thing, the boat handled perfectly well. It was light air and not much heeling.Divecoz wrote:Not Trying to de-rail this thread .. But I have heard of people doing this on purpose and gaining an edge... a little speed.. I "think" I have done this or very close heeling over and running the rail in the water.. ( wouldn't we all like to be part of the MadMen so our buds would film us??) So I ask Mastreb.. are you one of those who has done this? I have heard it said that running just one rudder at a time will turn her faster than with two.... when sailing "hard/fast"????mastreb wrote:Thehas two rudders. It only takes one to steer the boat perfectly well under moderate heel. The outboard lower unit makes a reasonable emergency rudder as well. Worst case, I've got two dinghy oars that could be tied down to serve as a jury rigged tiller. This is not a failure I would be worried about given all the redundancy available.
Doupirate wrote:There is a 6 miles per hour (5.2 knots) speed limit on the rudders use.
It is quite easy to exceed that limit under sails, downwind, keel up, surfing on a 5 feet wave at sea.
I am wondering if that limit is applicable on the rudders in the full down position, the boat listing 20/30 degrees, or if it is designed to protect the rudders attachments in shallow waters when the rudders are largely horizontal, or when the boat is excessively listing.
The stress on the rudders attachement looks about 5 times worse when the rudders are partially raised, so that 5.2 knots limit should be about 1 knot with the rudders raised to a horizontal position.
Thank you for clarifying.
I would venture to offer - speed does equal load! I was surprised to read the rudders even survived WOT when accidentally left in the down position! I don't think, given that, that they would have agreed too well with a rapid turn at speed.Doupirate wrote:Were you under sails or motoring?
Were your rudders in the full down position?
Were you listing a lot?
I remain sceptical about a speed restriction applying only when motoring....speed is speed, loads are loads....
Given a favorable weather window, you are much safer 50 miles offshore than 5 miles offshore which is safer than 1 mile offshore, which is much safer than 500 feet offshore.I, on the other hand, would NOT go 50 miles offshore
The rudders are always supposed to be in neutral position if you have a furler and if the apparent wind is constant. I usually sail solo on a lake and routinely leave the wheel under sails to go to the can.50 miles offshore i would have spare rudders on board, and also master sailing on course without rudders ...not as difficult as it sounds............
Yes! Easier on andlandersson wrote:Isn't it simpler to simply stand on the stern and pi$$ of the rear like a European fountain?![]()
