Great stuff Ross.
Thank you for sharing. I love your hydraulic steering – very well executed.
I really liked the smart idea of lowering the rudders. Wish I had thought of that when I did my steering mods. I would probably have incorporated the idea. Brilliant.
The maximum turn angle is not necessary under sail as you say. You will need it though in tight turns when maneuvering in close quarters in a marina and you have a side wind blowing you away. So, I would not eliminate too much of that.
It may also be useful for you to know that I have never run out of battery power using the autopilot, or even come close to that with the Sportpilot plus.
It seems that we share similar concerns and are annoyed by the same things.
You may, or may not, be aware of my three steering mods that I invite you to take a look at, that I hope you will find interesting. The Sportpilot is not in these pictures – it came on a little later.
http://www.macgregorsailors.com/modt/index.php?view=662
http://www.macgregorsailors.com/modt/index.php?view=663
http://www.macgregorsailors.com/modt/index.php?view=665
Further to all the above, I can give you some more input with regard to my Sportpilot plus.
-Positive feature: If you suddenly need to change course to avoid an obstacle you just grab the wheel and steer off. There is no need to disengage the system before you take over. I find this to be an extremely efficient safety feature and it has come in handy a couple of times e.g. when you see an obstacle floating, like a log, at the very last minute. On other systems you need to disengage before you can resume control of the wheel. So, it will take a few seconds more.
-Negative feature: The location of the steering mechanism (between console and wheel) has two drawbacks.
One, it increases the distance of the wheel from the console and this makes the wheel stick out from the console more. I can live with it but I would prefer to have the wheel alone.
Two, the steering mechanism is open to the elements of nature. The sun gets to it as does water spray when powering into seas that have a chop coming in at an angle to the boat (although this is much less now with the bigger engine that allows the boat to plane better). The latter is of great concern even if the system is rated to be 100% waterproof. I would prefer to have the system inside the console or below decks for protection, where it can stay totally dry. Victor (on this forum) is working on his self-made autopilot and I think has incorporated this important feature of putting the motor inside the console in his design. I like that.
When I have a lot of spray coming into the cockpit I cover up the console with a dedicated (light) foul-weather jacket that I do not use myself any more. I zip it on, it stays loose around the whole console and Sprotpilot and leaves the wheel free to rotate. This simple method is very good at keeping everything dry including the throttle stick of the outboard that you can still control precisely by holding it over the jacket. Alternatively you can put your hand through the sleeve and control it.
As for the steering system; I have had no second thoughts with my double cable system – it has worked extremely well and gives me the feel and sense of security I need with none of the silly play I used to have with the stock steering. So, for me I would not have a reason to switch from cable to hydraulic, although I do admire your system.
When my Sportpilot plus dies one day, would I readily replace it with today’s equivalent which is the SPX-5R that Matt refers to in his posting? Yes, without hesitation. It is a good pilot and has proven strong enough to deal with the torque requirements of our small boats. But, I confess, I would also examine a possible alternative of a system that is concealed, either in the console or belowdecks, just to have it protected from the elements and out of sight. I have not researched that avenue yet and I would welcome ideas if someone has any.
If I were to make a comment on your hydraulic steering as I see it, I would say that it is great to be able to have the potential of connecting an autopilot system inside the boat, but at the same time I feel that the drawback continues to be that to steer the engine you retain the original factory design with its deficiencies. The outboard continues to rely on the rudders and is steered as a secondary command off them rather than being independent.
In my opinion the Mac is more of a power boat than a sailing boat and the engine, especially if it is on the larger side, should have direct benefit of whatever steering system you are using as there is more demand on the engine steering, and the rudders for sailing should be the secondary concern. I think I would link the hydraulics direct to the engine, even if this means having the piston outside in the well, and then have the rudders working off the engine steering. Just a thought.
This web site is about exchanging experiences and knowledge and I believe there is always something to benefit from another person’s inquisitive mind. Please take my comments in the constructive spirit with which they were written.
Hope all this helps and thank you for sharing.
I look forward to hearing your counter comments.
Octaman
