Steering
Posted: Tue Feb 01, 2005 6:33 pm
No, older X's can't use a rack.
The older X's had a shorter pedestal with a rotary cable drive inside. To use the rack & pinion Roger had to raise the top of the pedestal.
If you replace the Detmar rack with a Teleflex rack the Teleflex helm needs a bigger hole AND the center of the bigger hole must be LOWER than the center of the old hole or the rack will not fit inside the pedestal. If you make the TOP of the new hole even with the TOP of the old hole it should be ok as it worked for me.
It is usually the cable that goes bad while the rotary or rack is ok. Try just changing the cable if you have an older Mac.
