Re: Water Leak Aft Bilge Under Bed
Posted: Wed Oct 10, 2012 7:58 pm
If you find the leak is from the ballast tank thru the inner hull, recommend you contact the factory - this is a latent defect that should not be subject to warrantee time periods. They need to do something to make this right. Solution may be as simple as a few layers of fiberglass on the inside of the inner hull. They also need to know this happened so they can investigate why.
Personal opinion - this failure would be really unlikely from manufacturing since probably multiple layers of glass here - any chance this was the site of damage (cannot picture how).
