I have thought about installing aluminum like dingy bracket on the stern and put on top a 120 watt solar panel and also use it for a dingy but the motor sticking out and the rudders up would make the brackets to far aft.
I could just build the bracket with width just for the solar panel and it would be perminate. I also like the Idea of the 120 watt so I never have to ck battery voltage and future elect. demands.
I also considered solar panels on Port and Starboard with a hinges. The unit would be up Sailing and down when anchored.
I have seen a few larger Sailboats with this arangement but they have more than 500 watts in 4-6 panels.
I still like the bimini with removable solar panel as it is low cost, but the fixed dingy is a self contained unit and you need to do nothing except cover it on a trailer for longer solar panel life.
Anidized Aluminum is the best choice over Stainless Steel for weight and costs and I never had a problem with salt water corrosion. Just rince off with fresh water.
I still have the Solar Panel project on the back burner and want to make sure the design and function work well, as I hate building something and after it's done ,I say I should have done this!
There are many options includeing a larger engine for more amps, a 4-D Battery, or 3- 30 searies deep cycle or 4 golf batteries, even another group house battery will give me 1-1/2 days more. That would be 4-1/2 days without recharge.
When you add another 100 lbs of batteries, that still is less than 130lb more 90 hp outboard and a whole lot less money.
I am running WM 24 AGM batteries on a pool shark at the water park I work at. Use to be group 27 wet cell deep cycle and they are much more effeciant and lasts much longer with no maintanace but costs.
I have built a wind generator back in 1983 in St. Thomas and in the Trade wind works best but not in the States except Parts of California or any are that consistantly gets at least 10 knots or higher winds. For get water generators as they clog up easy.
It's a lot of planning and for the Mac.X or M a lot more do to outboard overhang and rudders.
Divecoz wrote:DaveB I think we are on the same wave length on this one.. Have you any reservations with the solid platform collector? Is there an issue wit the aluminum frame work.. My brothers keeps hounding me on salt salt salt ..maybe even coat the frame with some sort of liquid plastic of some sort..
If I can save money here.... I feel I can spend more money over there.. if you get my drift..
I would like
1. solar .. solid platform is MUCH cheaper than flexible..
2. Built in A/C .... may have to bite the bullet on this one .. dang it you really need it to be water cool .. No DIY project here..
3. Built in fridge....I have thought about disassembling my dorm size fridge and seeing if I can build something to fit, out of the parts from that.. Issue is its only 110V. hum If I fail I am only out $60 and I used it for 5 years
4. Auto pilot
If a solid panel collector would work / last .. That could save me enough to buy the fridge..if 60 watts would do it and in Florida I think it would, that "could" eliminate lugging a gen-set..I dont like the gen set I have .. its really too noisy.. I wouldn't appreciate it if someone else started it up so I'm going to 86 it..
I am in no hurry and I do feel I need to limit the amount of money I am accruing in this boat..
