Page 2 of 2
Re: Sealed center valve - water ballast issue
Posted: Wed Dec 14, 2011 2:03 pm
by WidespreadSailing
P.S. My boat stays in the water 98% of the year down in the FL Keys.
Posted: Wed Dec 14, 2011 2:13 pm
by Newell
No plans, no pics, sorry.
This project was difficult to my standards. Because there is no pilot hole for cutting a larger hole into the transom ballast tank, it was necessary to make a plywood template that I screwed onto the hull where the new screws would go for the new gate valve. This guided the hole saw correctly. There is no room for error. :|
Posted: Wed Dec 14, 2011 3:20 pm
by Matt19020
If you need to cut it out with a dremmel you could use something like this to reseal the valve:
http://www.boaterbarn.com/images_produc ... 747big.jpg
Posted: Wed Dec 14, 2011 8:58 pm
by Hamin' X
You could nest a 3" hole saw inside the 4" one and use it as a guide.
Posted: Thu Dec 15, 2011 8:35 am
by Newell
Hamin' X wrote:You could nest a 3" hole saw inside the 4" one and use it as a guide.
Yes, if the factory placed the 3" hole equi-distant from the top and bottom of the tank. The factory was always perfect according to Roger? :wink:
Posted: Thu Dec 15, 2011 9:30 am
by Hamin' X
Good point. As always, YMMV.
