Come up with $100 and I will show you how to set up and underway in less than 15 min. on a video. We keep the boom with mainsail attached in cabin, tho we have a UV sail strip sewn in the 105 jib we also use a 1/2 cover that covers the complete roller furler.
We have a quick release bracket on our back stay that allows 2-1/2 inch slack. All standing rigging is in place when we trailer.
Arrive at boat ramp, Both of us undo the bungee cords holding roller furler and standing wires (4 min.) we than pull mast aft and secure the bolt to mast base and raise mast (2-3 min.) Teresa gets the boom out of main cabin while I run jib sheet lines aft and bolt in the boom,put in Mainsail slides and tie up topping lift along with main sheet attachment to boom. (3 min.) We than pull out mast support and attach Bimini and put dock lines on (2 Min.) we launch (2 min.)
I park trailer while Teresa puts cockpit cushions and lowers centerboard 10 inches and rudders. (2 min.)
This is very close to what we do tho times are faster if everything goes smoother with no tangles raiseing mast.
Two people is a snap as you don't have to use the Gin pole (I have a Mac. M pole I don't use).
By myself would take me twice the time useing the Gin pole.
I am 60 years young with back problems and still grunt rigging the boat.
Dave,
Didn't mean to offend or doubt you could do it, I just think people who ask should know the boat takes more then 15 minutes for most of us mortals. You have a system and teamwork effort happening that apparantly allows you to be the exception rather than the rule. I don't plan on coming up with a $100 but feel free to post to youtube; you are a "MacGregor Olympian". If you can get the 15 min video down to 3 mins that would be great
I have my boat setup similar to yours - my times are: (add 10% for my repeative stupidity)
Position the truck and trailer (2 mins)
Unhooked the brake Lights, take the safety chains off, walk around untie safety lines, take QR safety pins out of rudders (5 mins)
Get the stool place behind boat (1 min)
Get onboard, open cabin, store hatchway boards (2 mins)
Get tools from tool box and unstrap boom with sails attached in cabin (2 mins)
Unbolt mast and remove support straps in cockpit (1 min)
Remove bungees holding standing rigging (2 mins)
Remove support for roller furling and store in vehicle (1 min)
Unbolt mast and move back (5 mins)
Go below and get mast raising kit and rig (5 mins)
Raising mast and put forestay pin in (5 mins)
Remove mast raising kit and stow (3 mins)
Run the sheets (3 mins)
Get the boom and hook to mast, topping lift, main halyard, vang, sheet, etc. (5 mins)
Remove mast support and stow (1 min)
Put out the cockpit cushions (3 mins)
Raise the dodger (2 mins)
Place fenders and prepare docking lines (2 mins)
Open ballast, place key ignition, pump the ball, check battery gauges, put out the chartplotter (3 mins)
Walk forward on the boat for one last check get in vehicle and start to back down ramp (2 mins)
Stop when loud crashing sound is heard (1 min)
Get out of vehicle to find out ran over stool (1 min)
Get in vehicle move forward and remove crushed stool (2 mins)
Launch boat tending own lines (10 mins)
Go park vehicle (5 mins)
Lower boards, start engine, check ballast (1 min)
Leave dock and then return to get cooler left in truck (10 mins)
Rod
