Page 2 of 2
Re: 2003 Suzuki DF-50 No Spark
Posted: Sun May 30, 2010 7:05 pm
by Rocketman1098
Russ- thanks..good info!
Posted: Mon May 31, 2010 2:07 am
by Nautek
Make sure that you check your fuses with a multimeter as they can look good to the eye but in fact are blown
Allan
Posted: Mon May 31, 2010 3:11 am
I checked my Merc manual last night and in deed the safety lanyard switch is not a series loop, but grounds some signal from the main loom .
This means the check should be to ground both switch terminals to bypass it (checks both the switch and the ground connection)
Posted: Sun Jun 06, 2010 10:58 am
by sbods
Could the system relay "degrade" causing an intermittant problem, or would it be a total failure situation?
Is there any work-around to the relay when failure occurs? (short of replacement....as a get you home solution?)
Steve
:macx:
