2003 Suzuki DF-50 No Spark
Rocketman1098
- Nautek
Re: 2003 Suzuki DF-50 No Spark
Make sure that you check your fuses with a multimeter as they can look good to the eye but in fact are blown
Allan
Allan
I checked my Merc manual last night and in deed the safety lanyard switch is not a series loop, but grounds some signal from the main loom .
This means the check should be to ground both switch terminals to bypass it (checks both the switch and the ground connection)
- sbods
Could the system relay "degrade" causing an intermittant problem, or would it be a total failure situation?
Is there any work-around to the relay when failure occurs? (short of replacement....as a get you home solution?)
Steve
Steve
