Page 2 of 2
Re: How does a 26X sit when drying out?
Posted: Thu Jun 24, 2010 10:14 am
by Québec 1
Gary N wrote:Another question. When you dry out on a beach or mud, do you open the ballast to drain off the extra weight on the hull?
No, should I? How about the weight of the snow and ice?
Q1
Posted: Thu Jun 24, 2010 1:32 pm
by DaveB
I hope you have your axel jacked up on a stock Mac.Trailer. You must have at least a ton or more extra weight with all that snow and Ice.
Québec 1 wrote:Gary N wrote:Another question. When you dry out on a beach or mud, do you open the ballast to drain off the extra weight on the hull?
Q1
Posted: Thu Jun 24, 2010 1:40 pm
by DaveB
Look at my above picture of my last Post, you can see the stearn sitting on the bankment and bow at lower end. You can see under the hull for 6 ft. and full ballest.
The hull can easy take this, the ballest tank acts as reinforced stringers makeing the hull very rigid,also has very large stringers to support the Ballest structure.
Posted: Thu Jun 24, 2010 3:38 pm
I smell the 'ballast doesnt weigh anything under the waterline' argument heating up....Warning Warning...
Posted: Thu Jun 24, 2010 4:44 pm
by DaveB
Weigh anything? Whats that suppose to mean? A sling fore and aft to lift your boat for haul outs with full water ballest is same thing as fore and aft hull weight on a drop sand bar.
Catigale wrote:I smell the 'ballast doesnt weigh anything under the waterline' argument heating up....Warning Warning...
Posted: Thu Jun 24, 2010 9:27 pm
by Hamin' X
I wonder: Which weighs more, 1400 lbs of water, or 1400 lbs of lead?
Posted: Thu Jun 24, 2010 9:38 pm
by Québec 1
Hamin' X wrote:I wonder: Which weighs more, 1400 lbs of water, or 1400 lbs of lead?
The lead of course because it has more volume per degree of weight.
Posted: Thu Jun 24, 2010 9:57 pm
I'm too dense to get these concepts. I'll think about it Mass. If we all work on it together it would be en masse. Next stop Massey Paliseau!!
Posted: Fri Jun 25, 2010 7:18 am
by Québec 1
Catigale wrote:I'm too dense to get these concepts. I'll think about it Mass. If we all work on it together it would be en masse. Next stop Massey Paliseau!!
Obviously you are making allusion to the
Subquadratic computation of vector generating polynomials and improvement of the block Wiedemann algorithm
Posted: Fri Jun 25, 2010 12:48 pm
by The Mutt
1400lbs of water, 1400lbs of lead ... which one would hurt more if you dropped both of them on your foot?
Glenn
Posted: Sat Jun 26, 2010 1:55 am
by K9Kampers
The Mutt wrote:1400lbs of water, 1400lbs of lead ... which one would hurt more if you dropped both of them on your foot?
1400 foot lbs!...
Posted: Sat Jun 26, 2010 2:30 am
by Gary N
Wow. remind me never to mention the ballast weight again!
Anyway, thinking out loud here. The issues of opening the ballast after you dry out are:
1. The weight of the boat resting on the somewhat delicate hull is reduced. This may or may not be important but I can see situations where there just happens to be a sharp rock, lump of metal, etc under the boat that could damage the hull. Losing the ballast could reduce this risk.
2. If you are on mud, then the less weight the better so that you would sink less reducing the potential risk of the CB clogging up.
3. With no ballast, the boat will float off sooner when it's time to go.
4. The ballast gate should be shut after emptying so that stuff doesn't go in there.
Overall, I would think it would be a good idea to empty the ballast.
Posted: Sat Jun 26, 2010 3:21 am
Good points Gary, Sorry for swiping your thread.
(Andrew ....
I hope no one gets torqued up about it)
Posted: Sat Jun 26, 2010 8:33 am
by Hamin' X
Just keep pounding, Steph.
Old joke, Gary. There have been some interesting discussions on this subject; more like a food fight.
