Re: Air Conditioner - other ideas?
Posted: Sun May 23, 2010 11:39 am
Defenders has a sale on built ins, you will need a thru hull for water intake. Cost you around $1350 with everything.
Or you can do what I do.
$90 for 5050 BTU AC, $22 for 1/4 white Plexiglass and $3 for redwood support.
Here are some pictures.
http://s182.photobucket.com/albums/x25/ ... itionMacX/
jschrade wrote:I have seen the modifications for mounting the air conditioner in the companionway via a cut-out board but that is likely beyond my skills and a little too hard to stow.
My thought is to essentially sit the air conditioner right on top of the traveler heading into the cabin. Obviously providing a platform for it to sit on. Then just create a cut-out (in multiple pieces) to fill where the cabin slide in door would normally be. It would seem that this would be the simplest way to set this up and my intent if to try and find an A/C that would fit in one of the cockpit wells. with the door pieces. Has anyone gone down this path? This thought came when I was looking at some modifications where the cabin door was cut into pieces to make it easier to stow.
I'd love one of the carry on type A/C's but at $999 that is not going to happen.
