Page 2 of 2
Re: front mast stay pin
Posted: Mon Feb 01, 2010 2:42 pm
by Nautek
I replaced mine with a stainless steel bolt that i cut the thread off and drilled to take a stainless steel "R" pin from whitworths
I use this method for all pins except where the baby stays attach to the mast
Allan
Posted: Mon Feb 01, 2010 3:40 pm
by verena
We use a bolt with a nylon locking nut.
Posted: Tue Feb 02, 2010 4:23 am
by trip01
Allan,
I found these...
This one would support a captive cable. :idea:
http://www.whitworths.com.au/main_itemd ... lutePage=1
or..
http://www.whitworths.com.au/main_itemd ... lutePage=2
Kind Rgds
08 26M
Posted: Tue Feb 02, 2010 1:10 pm
by Nautek
Hi Dave
I used the retaining clip just because I had some however the humpback retaining clip looks good too
The chances of the retaining clip coming out is remote whereas the humpback might under some applications
Horses for courses
Just carry some spares
Allan
Posted: Wed Feb 03, 2010 1:48 am
by mike uk
What? Carry a spare mast?
(Only joking) :)
Mike
Posted: Wed Feb 03, 2010 2:00 am
by Nautek
Mike
If you had a blue boat with the fancy mast you might have to :evil:
Allan
Posted: Wed Feb 03, 2010 4:05 pm
by Highlander
Nope the M mast is bigger & stronger & longer. the X mast at 28ft is stretching the limits of that mast. the :mac19: has the same mast as the :macx: only the :mac19: mast is 24ft two sectional I extended the mast on my :mac19: to 28ft & made it a three sectional mast with a second set of upper spreaders & upper jumper struts it has two forestays & four sets of shrouds supporting it ten times more support than the regular :macx: mast at the same height :!: :idea:
Now go listen to me ya'd think I was from TX or something :D :D :D :D
J :P :wink:
