John B wrote:I can rig the boat in 19 minutes. The reason it takes me close to an hour is because of all the break downs. I go to loosen a finger tight nut and it hurts my fingers too much. I have to go down below, open a tackle box and fish around for a couple 9/16s wrenches. Five minutes later, I'm back in action. Where the heck is the back stay? Oh, there it is, all coiled up in a velcro loop half way up the mast.
Exactly. My 19 minute record was the one time when everything went right. The reason it usually takes longer is just as you say: the small breakdowns, glitches and do overs. There are a couple of keys to eliminating and minimizing these.
When I get out of the truck, two 9/16 wrenches are in my right pocket. Two 7/16 wrenches are in my left pocket. I grab my plastic, two step folding stepstool out of the back seat and carry it to the stern for boarding.
When I remove the rudder bolts the nuts go a half turn back on the bolts and they go in my left pocket. When I take the big bolt out of the bow pulpit, ditto in my right pocket; when I get ready to pin the mast base on the deck plate, I reach in the pocket and there it is.
The forestay pin is tethered with a stainless fishing leader. When I take out the ring ding, I hold it in my teeth. Haven't lost one since the first time I raised the mast.
When I have "help", and they ask what they can do, I tell them the best thing they can do is carry stuff from the truck to the boat to be loaded, then standby on the pavement and hand me stuff (usually one of the wrenches) that I drop.
Plan your activities to minimze wasted motion. Everything that needs to be done from the ground: pull and stow the tie downs, rudder bolts, disconnect the trailer wiring harness, is completed in a one trip around the boat before I ever get on. I use the plastic ladder for boarding over the stern. The trailer bow ladder is possible, but right there on the starboard pulpit is where my monster Bulwagga anchor resides, it's difficult to get past without damaging myself, and with the plastic ladder it's easier and only marginally slower to climb on and off through the stern. I've only backed over the ladder once, and it survived.
Once I climb on the boat, I'm there until I climb off to pin the forestay. My rig is way too tight to do this while standing on my head on the foredeck. Trips back and forth to the foredeck, cockpit, foredeck, cockpit, etcetera take time, and I plan my sequence of tasks for the fewest number of trips.
Bungees are my greatest tool. Nothing gets disconnected that can instead be left in place and secured with a couple bungees. I use at least a dozen, all the same length. When rigging, as I remove them, I loop them around my neck for temporary storage. When derigging, I carry them the same way to use as needed. If they're too long, running a long one twice around is easier than searching for a short one.
Most important, to minimize forgotten steps (like the backstay still bungeed to the mast as it's being raised) do things in exactly the same sequence every time. If your memory's like mine, make a list and consult it the first couple of times. Better yet, have your helper read stuff off to you as it occurs. After a few times through, most of it becomes second nature.
Let's face it, you're seldom going to get it perfect. But when there's a glitch, add another mental check or revise your procedure to prevent it; keep trying until you find something that works well. For instance, I'm still working on a reliable way to prevent the backstay from snagging on something (rudders, motor, stern cleats, pedestal, captain's seat) as the mast goes up. On the other hand, I haven't kinked one of the shrouds (one of my original problems) in a long time.
BTW, I was never able to get my derigging time below 30 minutes; average was more like 35. It simply took longer to get everytihng stowed and ready for a 50 mile trip, including 35 miles at 70 mph on the Thruway.
Time on the water is time well spent, time rigging and derigging, although important and necessary, is really time wasted. If it takes an hour each, instead of an hour total, there will be times times when you'll decide it's not worth the bother and you'll stay home.
