Page 2 of 2
Re: "M" Sliding Companionway Hatch
Posted: Fri Mar 06, 2009 4:49 pm
by Blue Liberty
Another fine and easy modification to do :wink:
Posted: Fri Mar 06, 2009 5:10 pm
Now that is much clearer :)
If the factory did it, the cost of the Mac would go up a couple of hundred bucks.
Posted: Fri Mar 06, 2009 11:06 pm
by puggsy
"Something like this should be done at the factory," I agree... and also maybe a built in multiple wire harness for accessories...but then, don't forget...the :macm: 's are built to a price...and a marlin board...Roger has my plan...and a bowsprit...and a...and a...and a...
dream on puggsy
Posted: Sat Mar 07, 2009 2:39 am
by pokerrick1
NiceAft wrote:That's like trying to explain how to tie shoelaces :P :wink:
That's easy - - - first tie the left one and then tie the right one 8) :wink: :D
Rick :) :macm:
Posted: Mon Mar 16, 2009 7:18 am
by baldbaby2000
I've had the same problem. I saw a mod where someone carpeted the inside of the hatch including the part that contacts the deck when sliding. He said it worked well. The velcro idea seems similar but won't sand still get between the velcro and the gel coat and wear it out?
Dan
Posted: Mon Mar 16, 2009 8:26 am
by Hardcrab
I don't know, time will tell.
It can't be any worse than the friction there from the factory.
I do know that there is vertical room to fully wrap the lip with velcro, top and bottom, instead of just the corners being doubled up as I have done.
In retrospect, a full "wrap" may help to hinder any grit from finding it's way to the sliding areas.
So far, it still feels swweeeeet to open and close the hatch!
Almost like high quality drawer slides.
(It dosen't take much to blow up my skirt, and this mod did).
Posted: Tue Mar 17, 2009 1:44 pm
by baldbaby2000
I'm wondering how it would work to put the velcro on the gelcoat instead of the sliding hatch? A disadvantage would be that it would have to be longer to extend forward and may not hold up in the elements but there would be no direct contact with the deck gel coat.
Posted: Tue Mar 17, 2009 10:32 pm
by Hardcrab
If your use is like mine, the gel coat on the deck is long gone in some areas.
Perhaps if you were starting out with a brand new boat ------.
I'd still put it on the hatch though.
