Page 2 of 2
Re: electrical connection
Posted: Sat Jan 23, 2010 4:45 am
by magnetic
I think there are maybe 3 gradations of risk here
:arrow: If the boat is indoors - a warehouse or large garage - then the main dangers are trip hazards rather than water. A plug-in RCD may be a sensible precaution
:arrow: outdoors on the trailer, water starts to be a problem because of puddles, bilges, condensation and rain; in these circumstances an RCD is surely a bare minimum, and a lot of thought needs to go into the socketry and keeping the connections free of corrosion
:arrow: on the water is a whole different ball game, due both to the inevitable motion of the boat, the proximity of other boats, and the presence of a large amount of water all around - and potentially inside - the boat. I have just installed a 240v 30A shorepower rig on my :macm: and this includes a bipolar RCD between the inbound socket and the 4-way distribution panel, circuit breakers on each branch (fridge, battery charger and aircon) and the 4th branch off to a line of plug sockets with individual 30mA RCD's for each of the devices which are not permanently hard-wired (kettle and chargers for vacuum cleaner, lantern, mobile phone, laptop, GPS and handheld power tools).
At the present time I do not have a Galvanic Isolator, as there are no metal parts permanently below the water line, but I do have the DC Negative strapped across to the AC Ground wire, mostly to avoid fire hazards but also to protect all of the 12v devices on my DC circuit if the battery charger arcs or shorts, causing a bridge between AC and DC circuits.
By far the biggest day to day risk in a Marina is that any failure in your boat's AC rig will probably trip the entire Pontoon; my Marina Manager is not easily persuaded to come to my assistance by resetting this if the incident happens outside of office hours :?
I really don't think that this is overkill and I will try to take some photos next week; the RCD's are inexpensive and the most pricey piece of kit was the AC distribution panel.
Posted: Sat Jan 23, 2010 3:20 pm
by Kelly Hanson East
are you sure your motor mount isnt in water?? It will be tied to the DC ground most probably....
Posted: Sun Jan 24, 2010 11:43 am
by magnetic
Good point! I was wondering what to do when I go down to the boat tomorrow - now I know! :D
Posted: Sun Jan 24, 2010 1:49 pm
by John McDonough
phil0044 wrote:If I want to connect my 26M to house electrical outlet can I just buy a 30 amp female to 15 amp male adapter plug and connect it to an extension cord?
In the past I have simply bought a 30-amp female Cord end, and using a regular extension cord I cut off the Female end and installed the 30-amp female cord end.
Working Construction, I have many extension cords laying around with broken or burnt ends.
