Page 2 of 3
Posted: Thu May 01, 2008 7:25 pm
by empet
Matt - i'm in your situation - transposed to the Hudson river - after a short stint of lake sailing I am putting her in the Hudson next week - 5 minutes from work - lunchtime sailing, maybe.....just need to watch that I keep my job, so i can pay for all the broken spreaders and mods...
Posted: Thu May 15, 2008 7:02 pm
by live2shift
What is the factory original rudder line setup on the M? I bought my boat used and it has one continuous line, is this stock, it sure seems funky...
Rudder lines
Posted: Thu May 15, 2008 7:45 pm
by Bill Earnhardt
Yea, that's stock
Posted: Thu May 15, 2008 9:15 pm
by Mistral
I have installed pulleys close to the rudders to make it easier for the admiral to pull them up. Replaced the existing rudder lines with the same diameter sheet. Just tied the old and new sheets together with some electrical tape and pulled them through. All in all a 5 minute job for both rudders.
Installed a pulley for the daggerboard as well, but that still does not make it easier if you get stuck in the sand.
Posted: Thu May 15, 2008 11:29 pm
by c130king
I did not realize the
came stock with a single line for the rudders. My PO mod'ed the rudders for 2 lines each. The pull-up line has been modified with a block for 2:1. Works great.
The pull-down line is seperate and runs through a hole in the top of the aft coaming (is that the right term?). There is a stopper knot in the line to keep it from running through the hole. When I release the pull-up line from the cleat the rudder will gravity fall. Then I pull on the pull-down line, the rudder then "clunks" into the full down position. I take the pull-down line and make one wrap around the cleat to hold it down. However, the tension is not too great so that if I was to hit something the rudders will overcome the tension and kick up.
Did not realize that this 2-line system was not stock. Never seen another
. Does anyone else have it setup this way? Seems to work fine...never had a problem...knock on wood...
Have read about the bungee mod, but I can't quite visualize how that works.
Posted: Fri May 16, 2008 3:29 am
by Mistral
Jim,
My mod is very much the same. I only have the blocks much closer to the rudders.
Re: Rudder rope replacement
Posted: Mon Apr 04, 2011 2:29 pm
by fishheadbarandgrill
I've reviewed this old post and don't see where anyone mentioned the size of the stock rudder line? I'd like to replace mine with the same diameter line but don't know what it should be. I don't want to go smaller because I like the grip a bigger line give me.
Bob
Posted: Mon Apr 04, 2011 2:44 pm
by DaveB
Mine was 3/8 inch Braided Dacron but I switched to 1/4 inch because I added two quick release cams (If rudders hit something the cams release line so no damage) and find rudders are easy to pull up without burns.
I find that cruiseing with the rudder lines on the cam saves me fiberglass repairs and bent Rudder brackets.
fishheadbarandgrill wrote:I've reviewed this old post and don't see where anyone mentioned the size of the stock rudder line? I'd like to replace mine with the same diameter line but don't know what it should be. I don't want to go smaller because I like the grip a bigger line give me.
Bob
Posted: Mon Apr 04, 2011 3:53 pm
Thanks. I'm considering that same mod.
Bob
Posted: Mon Apr 04, 2011 4:25 pm
by DaveB
Her is a link,
You need Port and starboard. They work great.
In winds over 20 knots I would just cleat the lines to the cleats unless you are in thin waters.
http://www.duckworksbbs.com/hardware/cl ... /index.htm
fishheadbarandgrill wrote:Thanks. I'm considering that same mod.
Bob
Posted: Mon Apr 04, 2011 5:52 pm
by Berber Boy
I'm another Dave that fitted the Cleats and they are a terrific safeguard. But I had to downsize the pull down rope to 6mm (1/4") to match the cleat size. You can also adjust the cleat's release point to suit your need.
Posted: Mon Apr 04, 2011 5:55 pm
Thanks Dave(s).
Posted: Sun Apr 01, 2012 4:15 pm
by c130king
Bob
Bob, (hopefully you will see this old post of yours again)
Did you replace your rudder line? I am about to replace mine. I bought 5/16 Sta-Set Polyester Braid. However I didn't get the job done today...couldn't figure out how to attach the new line to the old line so that I could pull the new line through as I pull out the old line.
Anyone got any hints on how to do that? I will take my heavy blue sailing thread and my big needle with me next weekend and try to "sew" the end of the old and new together.
Thanks.
Sailing on König
Posted: Sun Apr 01, 2012 5:42 pm
Jim,
Did the mod but didn't add the cleats. Use the same 5/16" line you have as a replacement. Answered your PM as well.
Bob
Posted: Sun Apr 01, 2012 8:05 pm
by Obelix
Jim,
Use adhesive shrink-tubing to connect the two ropes.
Obelix
