The spirit of Abbot & Costello are alive and well in my boat prep projects
Well I’ve gotten the edge taping done and the keel dropped for the anti fouling painting … except there are barnacles lining both sides of the trunk that weren’t visible when the keel was in place.
The keel pivot, now that it’s removed, shows measurable corrosion pitting of the frame and pin… fortunately I already have a new replacement frame and pin on hand from BWY. I just need to modify it with a longer lift bolt (which makes it more manageable to install/deinstall by myself). Yet another last minute project…
The keel was apparently repaired sometime in the past by one of the previous owners who only used a big chunk of resin instead of actual fiberglass
No way we are going in the water by the first of April at this point. More likely mid April or later at this rate not counting potential weather issues that may arise… Fribble.
Such are the plans of mice and men…
One day at a time…..
Best Regards
Over Easy
