Re: Mainsail raising issues
Posted: Thu Apr 11, 2013 10:00 pm
And for anyone else tinkering...I supported the free end of the boom by the large (brass) snap hook on the topping lift. The padeye on the end of the boom holds what I would best describe as a “spool” fixed to it. It doesn't have to rotate, it slips freely on the hook.
The hook clips onto the middle of the spool and allows the boom to rotate, while still supporting it. The crank handle, which is convenient, but complicates its utility slightly (and so I haven't often bothered with it, it does violate the KISS principle), was attached outboard to the spool. A handle (12” aluminum pipe with a clearance hole at one end for the crank axle) was mounted between the spool and crank to steady the whole thing while cranking.
-B.
This thread is so long, and my memory so short, I hope I haven't repeated myself on any of this.
-B.
