Don B wrote:SO where do you stow the "port-side lounge seat" when using the galley?
The "Seat" is nothing more than the cushion that snaps in. You can store the cushion on the aft berth, or v-berth, or anywhere you can put some leather-wrapped foam.
Don B wrote:How far forward do you slide the galley when you want to use it ?
All the way to the bow? Or just out of the aft stow area?
Just out of the aft storage area. The aft-end of the galley ends up being about even with the hatch when moved into the "Cooking position".
Don B wrote:What do you do if you need power to the galley for say a coffee pot ? Can you add receptacles easily along thePort side wall ? Reason I ask is you could not wire into the poertable galley easily without a quick disconnect.
I was thinking about that same question. That and the plumbing that would be required to connect to a fixed water tank. Not sure I have an answer, other than, "It will be interesting to see how this plays out."
Don B wrote:What has happened to the mirror and counter that was up in the bow/head area on the starboard side - is it all removed ?
Nope. Still there. That is the wall for the head. The counter is a bit smaller, and can be used as a "Bookshelf" type arrangement. Actually, it is quite nice.
Don B wrote:Wow !! I knew the bathroom was smaller on the M but not until this post did I learn that the bow sleeping area is shorter than the X . But in the M's defense the "Void-Aft" is larger from what I understand.
The v-berth is still usable by small-to-average adults, but no one in my family would fit. My sister is 5'10", and I'm the shortest of the boys at 6'2" (my brothers are 6'5" and 6'9").
Don B wrote:How far forward can you go in a M before the Head room shrinks? In an X a 6 footer can stand as far forward as the Port Galley.
It's about the same as on the old "M". A bit more head room than an "X". I can stand up in the galley area on the "M", whereas I have to duck a bit on the "X". The step up is a bit further forward on the "M" than on the "X", giving a much more usable cabin space.
Don B wrote:It sure will be nice to see some pics of this new M !!
I was going to try to get some this weekend, but my plans got changed for me. I'll be in the area, but I won't be in a car or on my own boat. So I may not be able to go in to snap the pics I was going to. I'll make a special trip down there soon to get some pics.
Don B wrote:And last of all where is the cooler in an M ???
The cooler is not stored under any seats on the old "M". It was stored in a cutout area in the aft berth area. I didn't see the cooler on the new "M", and I didn't ask. I'll make a point of finding out for you.
--Mark
