bow roller placement
- Jim Bunnell
- Location: Southfield, MI; Tohatsu TLDI 50, '03 26M hull # MACM 0019 C303
I have an '03 26M. Dealer sent me the bow roller that was added to the standard boat, but no placement information. Does anyone have a picture of a newer bow with roller, or is anyone willing to send approximate measurements? Does it lie tight and parallel with the stem, or is there a setback or angle involved?
Thanks
Jim Bunnell
Thanks
Jim Bunnell
- craiglaforce
- Jim Bunnell
Sorry, Jim, I haven't seen installation on an M. In fact, have only seen the M in a couple of boat shows, and don't remember specifics at the bow. In case it's useful perspective, we positioned the roller on my 26X just stb of the forestay and parallel to the centerline. Since the roller is ~2 inches wide, the anchor's shaft is offset from the bow by an inch. This presents no problem in hanging my Bulwagga. (If you wanted to angle the roller just off-center, I guess that would work too). It requires two persons to install, and it is heavily founded (at least by my estimation) using this process:
- * position roller and anchor
* determine bolting measurements
* determine external clearances to bow, furler drum, forestay tab, etc.
* determine internal clearances as best possible
* mark external holes, pilot drill
* fabricate backing plates (1/4" aluminum)
* endure an hour of cramped and twisted efforts to bed, back & secure
Mark, depends on which roller you choose, but I think none of the smaller ones would interfere with my furling drum at all.mgg4 wrote:I have a CDI FF2 furler on my X. Do you think your placement of the bow roller would conflict with the furling drum? Would I have to mount farther to starboard, and would I then need to remove the starboard bow cleat? ...
26M Bow Roller
My 2004 26M has the bow roller immediately to starboard of the forestay attachment, parallel to the centerline.
I have the CDI FF2 roller furler, and this placement for the roller is not optimal. As I pay out the chain, it runs against the furler drum. When pulling up the anchor, you have to stay low and heave from a less-than-most-effective position if you want to keep the line/chain from hopping off the roller.
It is not a huge issue, but somewhere low on my list of improvements is to figure out if I can offset this further to the right, or at an angle, or add a guide to it, or something to improve it.
Bottom line, I would not worry too much about where the factory puts it, but rather put it where you see it will work the best.
Regards,
AndyS
Regards,
AndyS
- Jim Bunnell
Re: 26M Bow Roller
Andy,Andy26M wrote: . . . When pulling up the anchor, you have to stay low and heave from a less-than-most-effective position if you want to keep the line/chain from hopping off the roller. . .
I don't have any problem such as you described. I didn't plan for it, but simple serendipity of roller choices might have saved me. Perhaps it's due to the BRM's roller slot (see above) which provides a deep channel to contain the rode and chain during the lift. (Incidently, the BRM slot is intended to firmly lock-down and stow a Bruce-style anchor, but I don't use or need the slot for that function).
Lifting the anchor was always an ordeal before adding the roller. My first hoist across the roller, I was very pleasantly surprised ... smooth running, and vastly easier (on lower back) than hanging over the pulpit. Impending installers might want to look at the BRM style for this operating aspect.
- mgg4
I was hoping to put a Bruce-style anchor on "Offline", so the BRM is probably the roller I would choose. I may have asked you this before, but I'm hoping to get some insights from anyone who might have an answer.Frank C wrote:Mark, depends on which roller you choose, but I think none of the smaller ones would interfere with my furling drum at all.
--Mark
- Jim Bunnell
